Weird AC problem
Weird AC problem
This is on weird AC issue on my is350
With AC ON:
it blows cold air when the car is moving. When I came to a stop and waited for green light, the air blow warmer and warmer and smell bad until I move the car again.
Needs a recharge or something went wrong with the AC?
With AC ON:
Btw, I also have a 350 (2010). Not sure if this is isolated. I would be interested to hear.
same problem here and have a 07 is250. sometime when driving on the freeway i have to push on the gas so it can down shift to 4th gear so it can turn on the a/c again. ill check all my fluids but not sure if that it, the a/c blows super cold when working so dont think it leaking or low on freon.
if someone finds a solution please post, sucks when you have other people in your car and they keep reminding you how the a/c sucks lol
it's the radiator fan & relay. The one on the right. They suggested that I replace the fan + relay + thermostat all together. Their price = 1k + tax. Sewell has the fan for $45 and the thermostat for $39, still trying to find the delay. I'll spend under $100 and do it myself :-)
check the coolant. the is from 08-10 has contaminated coolant issues that clogg up. check if the tempertures change correctly driver and passenger. check tsb L-SB-0018-11 heater core restriction.
Some 2008 – 2010 model year IS 250/250C and IS 350/350C vehicles may exhibit a variation
greater than 20F (11C) in HVAC vent temperatures between the driver and passenger side when
heat is utilized at the same temperature setpoint. Use the following repair procedure to address this
condition.
condition.
condition.
condition.
condition.
condition.
Thanks
