Front turn signal bulbs SOB to change!
Picked up some bluish white Polarg bulbs for the front turn signals from another CL member and just got done putting them in. What should have took less than 10min on other cars took about an hour to do on my IS350. Why take so long for 4 bulbs? Pretty much the front bumper has to be removed to access the area needed to change out the turn signal bulbs. Not just that, the reinforcement bar also has to be removed to access and change out the inner turn signal bulbs. I'm a pro at removing my front bumper so it's no big deal for me, but I can't imagine people who will faint seeing the bumper off the car to do this themselves. It must suck if the bulbs go out on a out of warranty car. Dealer will probably charge $$$ due to needing the bumper and reinforement bar to be removed to change out a bulb. Most people will probably just live with a burnt out bulb in this case.. Hmmmmm.. Lexus probably purposely engineered it this way... $$$
But yea, I changed them out to get rid of the egg yolk color, now they are blue haha.. CA law says the front must white or amber in color, so it's perfectly legal. (FYI, rear turn signals must be red or amber)
The front turn signal bulbs use 7440. Using chrome bulbs is a good way to get rid of the orange color showing through the lens.
I remember I had to remove my reinforcement bar to replace my driveside headlight. I could be wrong, if it is possible it'll definately be a tight fit to remove/replace. I think removing the reinforcent bar (6 bolts) to access the bottom of the headlights is easier than removing the headlights and then putting it back. I wouldn't remove the headlight unless it's absolutely necessary, might throw alignment slightly off.
I already changed my turn signal bulbs twice already, stealth bulbs then LED bulbs, yes it is kinda stupid you have to remove the whole bumper to change the turn signal bulbs.
What really bother me is the driver-side headlight washer fluid tube is connection the washer pump and the front bumper. (Tried disconnect then washer fluid all around floor) I barely have room to twist the bulb under the headlight housing since th front bump is on the way.
These will work, I'm ordering these for my turn signals. You'll need four of them (50W 6OHM). Just splice the resistors onto the positive and negative wires before the bulb.
http://cgi.ebay.com/ebaymotors/1X-50...Q5fAccessories
would you happen to know how hard it is to pull the orange reflector out of the headlight? i think that removed, plus led turn signals would be pretty dope. i was also thinkin of color matching headlight housing like honda did with some of the fit vehicles (if im not mistaken)
