Front turn signal bulbs SOB to change!
on another note, since you seem familiar with this stuff i bought hidS from http://ddmtuning.com/ last year and well when i have my headlights on auto if im not mistaken they would flicker and even when i turned them off completly. any ideas for that?? think i need http://www.ddmtuning.com/Products/Er...minator-3-PAIR
Finally got a pic for those wanting to see what the front signal lights look like in white. Other lights are PIAA yellow bulbs for the parking lights and Garax 6k for the low beam.
Sure, there are 7440 LED bulbs out there. However, unless you like your signals flashing rapidly, you will have to add a resistor to each signal led bulb to flash normally. I remember in the 90's fast blinking signals is a mod, lol, how times has changed.
Uber 1337 Moderator
Like the poster above me said, you can added 7440 LED replacements but will need resistors to avoid hyperblinking (unless you're into that). Another option is to install electronic flashers.
http://minkara.carview.co.jp/userid/...391/parts.aspx
http://minkara.carview.co.jp/userid/...839/parts.aspx
I happen to notice these new things from Philips! Maybe of interest!
Is there an easier way to get access to the front turn singal?
I had a look inside but could not see any access to the turn singal besides the low beam for my 2011 vehilce. I did feel below of the housing and felt something which could potentially be the securing mechanism for the front turn signal but could not confirm since I was able to reach it without removing the front airbox since I was putting in the F-Sport High Flow Air Filter in there but could not see.
