IS300 Torsen LSD into IS250
Old 08-12-11, 11:22 AM
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
Originally Posted by Gville350
Personal perference, I prefer the mechanical/helical gears of a Quaife LSD
Torsen LSD's are the original helical LSD. This is a Type 2 Torsen helical gear LSD.
Jeff, have you or others done the measurements to see if a 350 final drive ring gear would at all fit on a 250 diff/300 Torsen LSD?
It wouldn't, I posted the ring gear sizes already.
Originally Posted by evogt500
So let me get this straight, the older is300 has a real lsd and the is250 only has a semi LSD? Do you know what exactly is a semi-LSD and how is different from a torsion LSD? Its one of those mysteries on the Lexus brochure that no one really talks about. The Semi LSD and the 2-piston brake calipers on the IS250 (I only see one piston).
The IS300 has either an open diff or a T2 Torsen LSD optional. The IS250 has a preload mechanism to help with low speed traction (like on snow), after that it basically acts like an open diff. I've never seen any information anywhere that references 2-piston calipers on the IS250, they all only have single pistons. The IS300 on the other hand did have 2-piston calipers.
Jeff
Old 08-12-11, 12:53 PM
350FSport
350FSport's Avatar
Personal perference, I prefer the mechanical/helical gears of a Quaife LSD :
http://www.autotech.com/product/oem-...arts-clearance
Can somebody explain what I am getting for $1k here? How would this make the stock 350 different in plain English?
Old 08-12-11, 01:00 PM
kinglexus99
kinglexus99's Avatar
^^ lol, I second that.
Old 08-12-11, 01:14 PM
laobo979
laobo979's Avatar
Simple give even power to the rear wheel so you get better traction. Most people dont need this for daily driven cars. Its great for the places where it snows or those who track there car. I had LSD on my ITR and M3 E46. It did wonder in the snow time for a rwd car.
Old 08-12-11, 01:31 PM
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
It also affects cornering performance as well.
There is a lot of information on www.torsen.com related specifically to helical gear designs. Clutch and other designs will vary quite a bit in their application.
Jeff
Old 08-12-11, 01:44 PM
prankster
prankster's Avatar
Are you guys race your IS cars? Just wondering what you guys are trying to achieve.
Old 08-12-11, 02:25 PM
Sango
Sango's Avatar
Comes in handy in general,. especially in snow conditions.
With open diff in know, one tire up in the air, you're almost out of luck by getting stuck as the wheel on the ground won't spin up. True locking diff, won't have that issue since the tire that's still on the ground will spin up.
Old 08-12-11, 02:27 PM
evogt500
evogt500's Avatar
With a proper LSD, the power is sent to the tire with the most traction helping acceleration, turning/cornering and well as tire wear. Its not just for racing.
As for the IS250 2 piston caliper info, look here:
http://www.lexus.com/models/IS/detai...fications.html
Under Chassis\ Brake size, it clearly states:
Two-piston front calipers. 11.6-in ventilated front, 11.4-in solid rear discs.
By the way, that is Lexus's own website.
Old 08-12-11, 02:39 PM
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
Yeah Lexus.com's information is weird/off on a few issues. Not sure why that is.
As for why you'd want an LSD, it affects the way the car handles in more ways than just launching, etc. Superior handling (especially when tracking the car, but even just spirited driving through the mountains, etc.). It's not just for high powered cars either, there's a reason cars like the AE86 came with an optional LSD, as well as many other cars.
Torsen LSD is superior in almost all situations, that's why.
Jeff
Old 08-12-11, 07:09 PM
Gville350
Gville350's Avatar
Here's some good reading if you're at all interested at all about LSDs :
http://www.limited-slip.com/acatalog...LSD_Works.html
Old 08-12-11, 07:33 PM
IS250TW
IS250TW's Avatar
Trying to achieve this maybe?
http://www.youtube.com/watch?v=EfWi1OMmg6I
IS250 with 1.5 way LSD....
I can't think of others.. lol
Old 08-12-11, 07:43 PM
Sango
Sango's Avatar
Speaking of that..
http://www.youtube.com/watch?v=ISlMOj5DUF8
http://www.youtube.com/watch?v=DFo91DHCsdw
This should would show how the differential worsk, lego style!
http://www.youtube.com/watch?v=lpf2pK-gGKk
Old 08-13-11, 07:22 PM
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
A couple of parts came in today, so I spent a bit more time cleaning up this diff before it goes in my car. Still waiting for 1 of the seals, the fill plug and the case cover bolts. I reused the old bolts to get it assembled today, I'll change them out when the new ones arrive. Why am I changing them? I don't know, I'm dumb; it's best not to ask why.
Cleaned, repainted housing, IS300 axle stubs removed (these are not reused for the IS250), seals removed:
Cleaned differential cover, type 1281 silicone sealant applied:
Cover installed, drain plug installed, new side seal installed, looking relatively decent now:
Just need the last few bits and it can go into the car. At this point it's basically just an R&R on the differential carrier now, as from the outside both diffs look essentially identical. It's the inside that counts though .
Jeff
Old 08-13-11, 10:01 PM
cookies
cookies's Avatar
looking good keep us updated
Old 08-14-11, 03:59 AM
ramainli
ramainli's Avatar
Looking really good. I'm really interested in how this turns out.
Quick Reply: IS300 Torsen LSD into IS250
