Under Passenger Seat Wet?
Our car so far has 3 main things that go wrong that can cost a lot of money: spring recall, navi touchscreen breaking, and this recall. The first two are easily fix, and I suggest everyone take care of them before they happen.
There's only one indication of seeing this, you turn on your ac full blast and look underneath your car to see if its leaking water, if its not, then the water is being backed up. You won't notice your floor is wet until there is a lot of water underneath your carpet, and by then your carpet is probably moldy.
I suggest you just do the tsb yourself, its not very hard if your somewhat handy. There's just a drainage plug you have to remove near the top of your transmission.
well its hard to physically check the plug because its obscured by the transmission, but you just want to see if water drips down onto the ground when your AC is running. If its not, then its most likely backed up. Its pretty hard to tell the extent of it backed up, without taking out your carpets.
However, if you just remove the plug completely (as described in the tsb) it would completely remedy the chance of the plug being backed up. The tsb also shows that the dealership replaces the plug they pull out, but once I pulled out my plug, i realize it was going to be very difficult for anything to go up the drain, so putting in a new plug isn't really necessary IMO. In addition, I did not have the new plug in my possession since i was out of warranty haha
Seems like a few Shelbys are up for sale. I saw a GT convert that was a 2008 with 15k miles on it. The guy bought it for his wife and she never drove it, never wanted it. It was for sale for 1k less than I bought Micaiah for. This one only has 500hp though.
Check it out
http://www.myhotcars.com/inventory/m...HT89S285192952
Check it out
sorry man. This happend to me twice with 2 diff camaros I had. It was only in the passenger side. I just wet vac't it and clean the carpet. Hope it goes well. Im fairly close to Nashville, so if you decide to part out let me know. I love the wheels bro.
