Oil Changes -
Old 05-24-11, 07:08 AM
NickTomsyc
NickTomsyc's Avatar
Default Oil Changes -
Just wondering which I should go by...
Using Mobile One Synthetic which I believe says 7500 miles between changes but I think Lexus says it should be done 5000 miles... is there a reason they would call out for this?... I plan on checking the oil after work, and I assume it will still look just fine.
Just wondering what miles/time intervals you guys are using when running synthetic oil
Thanks
Old 05-24-11, 07:22 AM
nastyemu
nastyemu's Avatar
5000 for synthetic? sounds excessive...
pretty sure 5000 is the modern interval for dino oil.
Old 05-24-11, 07:50 AM
NickTomsyc
NickTomsyc's Avatar
Thats what I was thinking... Thats all I've ever used (didn't know what the previous owner had done so I figured better be safe and good with synthetic, but I just hit 5k since my first change and now am wondering should I do it again this week or push on to 7500 and see.
Usually wouldn't care, but this is my first "nice" car and I just want to make sure I'm doing things right
Old 05-24-11, 08:04 AM
jbjones85
jbjones85's Avatar
I do mobil1 full syn every 5K. Oil/Filters are cheap.
Old 05-24-11, 08:53 AM
Kurtz
Kurtz's Avatar
Free is even cheaper.
You're literally pouring money down a drain changing synthetic every 5k in normal driving.
This has been proven over and over and over with every used oil analysis I've ever seen on a 2IS.
In normal (ie non-severe-duty) driving there's no reason whatsoever to change any sooner than 10k miles (and most folks can safely go longer than that.. but UOA is the only way to be sure how much longer)
Old 05-24-11, 08:58 AM
ELL Y
ELL Y's Avatar
I have been doing 10K on Mobil 1. I do have to top off somewhere in the middle of that interval or else the oil runs low. A dollar saved is a dollar earned
Old 05-24-11, 09:52 AM
Sffd103
Fire Slayer
Sffd103's Avatar
Costco has a 6 pack of Mobil 1 for $36. All you need to do is buy 1 at the auto parts store and a filter from Sewell.
MotoX
MotoX's Avatar
I changed my oil every 5k miles using Mobile1. The last time I changed my oil, its totaly black in color, not even brown. I think something wrong my car.
Old 05-24-11, 10:25 AM
Kurtz
Kurtz's Avatar
The color of your oil has nothing to do with the condition of your oil.... you can't tell how good a shape it's in by looking at it.
UOA is the only way to know how much life your oil has left in it (but assuming normal driving it had a lot more left in it after a 5k change)
Old 05-24-11, 10:47 AM
BLexodus
BLexodus's Avatar
Walmart sells Mobile 1 full synthetic in a 5 qt jug for $24.50. I usually buy 3 and change the wifes car and still have some left, (then I only need two the next time).
I usually change mine twice a year with full synthetic, though I am debating on changing to every 9 months or possibly just once a year.
My brother, who is a service manager at a toyota dealer only changes his once a year with the cheap stuff, he is convinced that its all it needs.
Old 05-24-11, 11:29 AM
IS-SV
IS-SV's Avatar
10K intervals on my IS350 w/Mobil1 by my Lexus dealer, they have no problem with it.
Old 05-24-11, 11:48 AM
cloo7
cloo7's Avatar
do u guys think leaving the oil in the engine over an extended period of time is not good?... thats if you don't hit the desirable mileage
Old 05-24-11, 12:31 PM
P51SN95
P51SN95's Avatar
what are you guys using for oil? I can't find the "required" 0w-20 anywhere Some Wal-marts carry 0w-30 but not the 0w-20
Old 05-24-11, 12:43 PM
BLexodus
BLexodus's Avatar
I use the 0w-30, I'm not an oil expert but I dont think it will harm your engine. It should provide even greater protection right???
Old 05-24-11, 12:49 PM
BLexodus
BLexodus's Avatar
When I had my S2000 I did some research because I only put about 4-5000mi on it a year. Most people say to change it once a year regardless of mileage because the additives in the oil can start to lose their effectiveness after one year.
I wouldnt go past a year, just to be safe.
But I'm sure some (honda/toyota) driver out there has gone 100k and 6 years without changing thier oil and their car is probably still running.
Quick Reply: Oil Changes -
