how can you tell about headlights
Old 05-18-11, 12:42 AM
aslowdodge
aslowdodge's Avatar
Default how can you tell about headlights
How can you tell if an IS350 has standard headlights, HID's, or Adaptive lighting. Is there a way to see the difference just looking at the headlights?
Old 05-18-11, 02:32 AM
Silkky
Silkky's Avatar
I believe all headlights with HIDS came with AFS. You can't tell which ones they are from the outside because they all look the same.
Old 05-18-11, 04:24 AM
Kurtz
Kurtz's Avatar
All 06-10 models with HIDs have AFS.
Easy way to tell is see if there's an AFS ON/OFF option using the multi-display switch. (the one that looks like <o> to the lower left of steering wheel).
If you don't have AFS you don't have HIDs
(06s are even easier- if it has memory seats it has HIDs, if it doesn't, it does not have HIDs... 07-10 cars if it has memory seats it has HIDs, but if it doesn't it still could have em and checking the AFS on/off option is the easiest way to tell)
Old 05-18-11, 04:38 AM
DAZ1
DAZ1's Avatar
Most, not all, cars with HIDs have headlight washers, noticable on the front bumper cover.
Attached Thumbnails how can you tell about headlights-dsc00269.jpg   how can you tell about headlights-dsc00492.jpg
Old 05-18-11, 08:18 AM
Kurtz
Kurtz's Avatar
Not true at all (on a national level) and the 2 options have nothing to do with each other from a factory build perspective.
Headlight washers (on 06-10 cars anyway) are a relatively rare/obscure standalone option... while HIDs are far more common (and on 100% of cars with the lux or sport packages for example)
Old 05-18-11, 01:41 PM
shizblam
shizblam's Avatar
Headlight washers are definitely not an indicator of the type of headlights.
Old 05-18-11, 01:54 PM
KillaIS250
KillaIS250's Avatar
Yeah headlight washer's dont indicate anything, in fact they are a kinda rare option, i've only seen a couple even at the big meets with the headlight washers lol
Old 05-18-11, 02:30 PM
edgeucated
edgeucated's Avatar
I have never seen the headlight washer option on an IS before haha
Old 05-18-11, 02:42 PM
kumquatism
kumquatism's Avatar
Until now, I had no idea there were even headlight washer options available.
Old 05-18-11, 03:16 PM
Fsport350
Fsport350's Avatar
https://www.clublexus.com/forums/is-...id-lights.html
Old 05-18-11, 03:52 PM
Trza
Trza's Avatar
Maybe one of the experts can chime in. My car has the damn headlight washers. I hate them because they leave streaks of washer fluid all over the bumper and fender. Huge bummer esp. after a wash This could be a Canadian thing?
Old 05-18-11, 05:32 PM
Bichon
Super Moderator
Bichon's Avatar
No, mine has them too, and I bought my car off the lot in NJ.
Here is the solution to your problem: https://www.clublexus.com/forums/is-...ml#post2299117
Old 05-18-11, 06:40 PM
Trza
Trza's Avatar
@Bichon, thanks man! I was hoping there was a way to disable them. I have a 2011...should still work? I'll give it a try this weekend
Old 05-18-11, 07:05 PM
DAZ1
DAZ1's Avatar
Wrong. You won't find headlight washers on a halogen equipped car. Exception, when the front bumper cover has been replaced with the washer cut outs.
Most manufacturers, MB, BMW, Porsche, even domestics, include washers with factory HIDs. The theory is, they're used for removing ice from the lens than washing, since the HIDs don't produce the heat that halogens do.
It's a option on all 2011 IS models with factory HIDs. Almost worthless in my opinion.
Old 05-19-11, 05:32 AM
Kurtz
Kurtz's Avatar
You certainly can actually.
It's a $100 option that has no relation to the type of headlights on the car.
It's an option on 2011 2IS regardless of headlights.
And a very rare one, again regardless of the type of headlights.
Lemme help you out:
http://www.lexus.com/models/IS/features/pricing.html
Notice where it says:
Headlamp washers $100
down near the bottom?
Notice how it has no relation to the type of headlights on the car? (as evidence of this it's a $100 option on the AWD 250 for example... a car where HIDs are optional and the two options aren't dependent on each other)
More importantly though- there's a ton (overwhelming majority) of 2ISes with HIDs that do not have headlight washers.... hence suggesting looking for headlight washers to determine if the car has HIDs is incorrect advice.
Quick Reply: how can you tell about headlights
