DIY: 2006 IS250 sealed transmission replacement
Old 12-06-14, 12:07 PM
  #31
Blackguy
Blackguy's Avatar
Default Bellhousing
I just have one question how did you get the top bell housing bolts out in having trouble with them I'm not sure if I should go from under the car or from the engine bay please reply asap
Old 12-06-14, 04:23 PM
  #32
Ants350
Ants350's Avatar
Originally Posted by BorIS250
Awesome job gays!!! Thanks to you I was able to swap my transmission by myself in 9 hours, ... My car has 160k but with this 2012 transmission with only 1000 miles it feels like a new car. I attached some documents for anybody up to the challenge. I followed this particular disassembly order: 1- remove lower oxygen sensors 2- remove "Y" muffler 3- remove drive shaft 4- remove lower engine plastic covers 5- disconnect top oxygen sensors 6- remove Headers left & right (top bolt from above and lower bolts from underneath the car) 7- remove transmission rubber mount while lowering transmission with a floor jack. ( fluid and coolant needs drainage at this point) 8- unbolt and disconnect Starter. 9- Unbolt Torque convertor from above. 10- Disconnect trans heater houses. Unbolt transmission using pneumatic or electrical 300lbs impact drive tool and long extensions (17mm bolt are super tight) 11-Remove transmission. 12- Remove A/C water drainage plug !!!! If you ever had trouble with water inside your car carpets. TORQUE CONVERTOR NEED TO BE WELL PUSHED IN AGINST TRANSMISSION HOUSING FOR ASSEMBLY.
lmfao gays??
Old 12-09-14, 06:11 PM
  #33
BorIS250
BorIS250's Avatar
Hi, sorry I hope it's not too late.
With the jack underneath the transmission, remove the transmission bracket and lower your jack until transmission touches and is supported by the chassis and the top bolt become visible and ready to use a super long 1/2" extension and a 17" elbow socket, then use a 400 flbs Impact wrench or bigger to loosen up the bolts and you are all set.
Raise your transmission to level, slide out tours back to clear chassis and lowere...... Be sure to have disconnected coolant houses.
Good luck!
Old 07-20-16, 08:12 PM
  #34
istundra
istundra's Avatar
Default A960 Document - attached!
page 5 for filling procedure!
File Type: pdf
Timmay1269 (03-08-20)
Old 07-20-16, 08:16 PM
  #35
lysis250
lysis250's Avatar
Can you attach the same file for the A760E or PM me the document, I would appreciate it.
Old 07-20-16, 08:49 PM
  #36
istundra
istundra's Avatar
http://shop.ukrtrans.biz/wp-content/...logs/A760E.pdf
this one is for the IS350. FYI, i just google search "toyota a760e" and it came up.
Old 07-20-16, 09:30 PM
  #37
lysis250
lysis250's Avatar
Thanks, I tried before and couldn't find it. That manual is for the tundra tranny in looking for the IS350 specifically. I know there were at least 2 different versions of this tranny made for the IS350.
Old 07-23-16, 11:45 AM
  #38
istundra
istundra's Avatar
no worries. i didn't realize it was a760e for Tundra until after.
Just picked up a A960E from JDM TOYOTA Mark X with 4GRFSE 2.5L. Seller says it fits IS250. Going to install in a few weeks.
Old 07-23-16, 12:43 PM
  #39
lysis250
lysis250's Avatar
Good luck, it's probably something I would never do myself ever again, maybe on the IS250 there's a little more room to play around with.
Old 07-23-16, 03:38 PM
  #40
Parsa
Parsa's Avatar
ive been putting off my transmission issues for a while now with everything else going on in life... ik its not good to do. It sometimes slips first to second gear also throws engine code for the infamous TCC solenoid. I was going to talk to a transmission shop and ask if I should get a whole new transmission or if they can just fix the solenoid. I heard it can be either way and they can only tell once the tranny is open, any info on this? thanks guys
Old 08-01-16, 06:40 PM
  #41
istundra
istundra's Avatar
Default A960E from JDM Toyota Mark X with 4GRFSE 2.5L - Fits IS250
Hello,
I want to update everyone that A960E from JDM Toyota Mark X with 4GRFSE is identical to Lexus IS250!!!
The installation of this JDM transmission went smoothly and functioning normally as expected!
Old 01-02-17, 04:22 PM
  #42
Solara350
Solara350's Avatar
Originally Posted by Jeff Lange
While I've changed a few trannies, I find the most impressive part to be the picture taking. It would take so much longer if you were always stopping to take pictures, haha.
Jeff
you only talk you never dismantled any Lexus trans nor engine
Old 01-04-17, 11:18 PM
  #43
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
What are you talking about? Of course I have, I've posted multiple builds I've done over the years, and I have built multiple engines and transmissions (I haven't rebuilt any automatics, but I have replaced them). Granted they weren't all Lexus-specific, but the 2JZ I built for my brother's Supra had a block from a JZZ31 SC300 if that counts, lol.
Jeff
Old 01-04-17, 11:36 PM
  #44
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Smallport 4A-GZE during reassembly after I honed the block and replaced the rings and bearings using early largeport 4A-GE 16V cams for my AE86 build. I also disassembled the T50 transmission and cleaned/resealed it:
Building a 2JZ-GTE with Tomei rods and pistons for a JZA80:
Pulled apart the 2GR-FSE before swapping it into my IS to inspect and swap parts from the 4GR:
I've built several other 4A-GE's, 2JZ-GTE's, and removed/installed many other engines and transmissions over the years.
I'm still confused.
Jeff
Old 01-05-17, 08:54 PM
  #45
Gville350
Gville350's Avatar
^You're not the confused one Jeff! LOL
Quick Reply: DIY: 2006 IS250 sealed transmission replacement
