Mount stock rear wheels up front?
Old 04-04-11, 12:27 PM
TheAnhDy
TheAnhDy's Avatar
Default Mount stock rear wheels up front?
I have a cracked front wheel I need to replace. I found a pair of stock rear 18x8.5 for sale but I need to know if the rears could be used up front because they're wider with different offset. Anyone out there have this setup with pics? Pros and cons? Thanks
Old 04-04-11, 12:40 PM
XhyDra
XhyDra's Avatar
If they don't come with tires then get them and install them they should work fine with some 235/40/18 or 245/40/18. You might have tiny rubbing on the fender liner in front nothing of concern. It's the same place people usually get rubbing. Nothing on the actual fender or component. Go for it. I'll go as far as saying you might be able to push the 225/40/18 stock tire size on it.
Old 04-04-11, 12:42 PM
KillaIS250
KillaIS250's Avatar
You could use the rears up front but why would you want to?
I'm assuming your car is a RWD? Staggered is better/preffered for RWD. Non-staggered is better/preffered for AWD.
Old 04-04-11, 03:08 PM
iRock
iRock's Avatar
I would think you could if you needed to. I've seen people run 9"up front. Your rim so bad that it cant be repaired?
Old 04-04-11, 05:41 PM
robertrios
robertrios's Avatar
our wheels are not staggered by much if unless you do some intense touring or something your not loosing anything in performance with matching wheels up front and in the rear. Ive mounted them and know they work. If you go with 235 or 225 tires all around youll now be able to rotate your tires and increase their life. I know a few people that has done this and are very happy with the results.
GO FOR IT!
Old 04-04-11, 06:18 PM
TheAnhDy
TheAnhDy's Avatar
Please take a look at this hair line crack on my wheel and tell me if it's fixable. It can still hold air when inflated but will slowly leak out within a day or less. Thanks
Old 04-04-11, 06:22 PM
CarbonDtls
CarbonDtls's Avatar
Crack looks repairable. You can run the wider wheels up front. Only issue would probably be more understeer.
Old 04-04-11, 08:14 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Definitely looks fixable.
Jeff
Old 04-04-11, 08:18 PM
Sffd103
Fire Slayer
Sffd103's Avatar
That's an easy fix!
Old 04-04-11, 08:28 PM
TheAnhDy
TheAnhDy's Avatar
Thanks for the advice guys, I found a guy on e90post that can do it for $90.
Old 04-04-11, 08:30 PM
robertrios
robertrios's Avatar
yea thats not bad at all!
Old 04-04-11, 10:08 PM
DreamerzCC
DreamerzCC's Avatar
I took a cracked wheel which was bigger than that to a wheel shop and they welded my rim. find someone who can do that and you'll be fine.
Ken167
08-10-16 06:17 PM
djrazr
SC- 1st Gen (1992-2000)
05-19-10 07:09 PM
IS07
06-07-08 04:31 PM
sincityIS
07-07-07 02:22 PM
dsdfan
03-30-06 07:12 PM
Quick Reply: Mount stock rear wheels up front?
