New intake filter installed = reduced mpg
Old 12-17-10, 02:06 PM
sop
sop's Avatar
Default New intake filter installed = reduced mpg
I recently replaced my intake filter and i noticed that i was getting worse gas mileage than i did with the dirty intake filter. i usually get about 24 mpg but now im getting 19 mpg. this is off the tank average reading.
I was thinking that it could have been due to the more power output. i did notice that it is more torquey which makes sense. more and faster air movement without too much resistance and better combustion.
If anyone has any knowledge or experience on why this is happening, please let me know.
Old 12-17-10, 02:36 PM
someboy
someboy's Avatar
I actually tried to switch between F sport pipe + Oem box and F sport intakes just to see if there is any MPG difference.
I drove with OEM intake for 3 months and F sport intake for 3 months and my results are:
with F sport intake: around 18.5 MPG all the time
with F sport with OEM intake box: 20-21 MPG all the time
So there can be a difference in changing the filter too.
Are you sure you did not drive more aggressively after changing the filter?
Old 12-17-10, 02:54 PM
sop
sop's Avatar
That seems logical but I'm running the oem intake and oem filter.
Old 12-17-10, 03:14 PM
DRivera250
DRivera250's Avatar
are you calculating the MPG yourself your relying on the tank avg to get the MPG?
Old 12-17-10, 03:44 PM
sop
sop's Avatar
I was looking at display on the dash. I usually know how many miles I get after getting to a 1/4 tank of gas. This time it was burning up much faster. I usually get to about 90 to 100 miles on the 1/4 tank. Now its about 75 miles.
I was thinking about this for a little more and could the cold weather in MA contribute? Cold air makes more power but use more gas. Hot air uses less gas.
Old 12-17-10, 03:55 PM
huntarrr
huntarrr's Avatar
You really need to calculate the ACTUAL mpg's. Fill up the tank til the pump 'clicks'. Reset the trip to 0. Drive around, fill the tank again, divide total miles driven by gallons. If you do this both on the oem intake and the new filter it will get you comparable results. This is the best way to rule out most of the variables that are controllable.
Old 12-19-10, 01:42 AM
Jetfire
Royale with cheese
Jetfire's Avatar
your gas is winter blend. prevents it from freezing. i consistently get worse fuel economy when they switch over. it's just a part of living in colder climate.
Old 12-19-10, 02:58 AM
jadu
live.love.laugh.lexus
jadu's Avatar
^^^ that explains it.. i completely forgot about winter blend. crappy mpg for the next few months
Old 12-19-10, 08:11 AM
ping83
ping83's Avatar
Bingo.......exactly! My cars dropped off 3 mpg because of the blend!
Old 12-19-10, 05:06 PM
llamaboiz
llamaboiz's Avatar
..I was thinking that it could have been due to the more power output. i did notice that it is more torquey which makes sense...
*cough*placebo*cough*
Old 12-19-10, 05:26 PM
windex
windex's Avatar
Your gas milage is worse because all you want to hear the 300-400 wasted dollars
Old 12-19-10, 06:38 PM
CLIS250
CLIS250's Avatar
i actually had swapped in and out my f sport intake, f sport intake box and filter compared to the regular pipe filter and box. same thing. less gas mileage with the f sport intake box and filter.
Old 12-19-10, 08:42 PM
sop
sop's Avatar
Thanks for all the answers and replies. Finally makes sense on why. I thought there might have been something going on with the car.
JulezLexx
08-02-17 03:42 PM
silkx3
Performance
18
09-19-16 10:18 AM
EJC
IS F (2008-2014)
18
06-14-12 06:29 AM
reyoasian
Performance
04-05-12 09:49 PM
jmg330
RX - 1st Gen (1999-2003)
01-06-11 08:48 PM
Quick Reply: New intake filter installed = reduced mpg
