Tire size Question
Old 11-10-10, 10:48 PM
chikoo
chikoo's Avatar
Default Tire size Question
The IS250 comes with rear Stock Tire - 225/45R17
Optional upgrade - 255/40R18
Speedometer Difference: 4.242% too slow with the optional 18".
Question: The speedo is connected to the front wheels?
If so, it is ok.
Old 11-11-10, 05:27 PM
sktn77a
sktn77a's Avatar
Older cars had mechanical speedometers connected to a front wheel. Most current cars have electronic speedometers based on engine speed and gear position (ie rear wheel speed).
Old 11-11-10, 06:57 PM
chikoo
chikoo's Avatar
ouch...so how does this work out when the car comes with 18" optional tires?
Does the factory calibrate the speedo for the 18" differently than the 17" standard?
Old 11-11-10, 07:34 PM
ScKcBc
ScKcBc's Avatar
rwd is250's have 245/45/17 in the rear, not 225.
And the sensor is in the front, not the rear.
225/45/17 is what comes stock on the front. Compare that to the stock 18" tire size, which is 225/40/18 and they're only about 1/10th of an inch different from each other
Old 11-12-10, 01:57 AM
Sango
Sango's Avatar
For the Lexus vehicles, it is already calibrated from the factory (assuming proper size spec tires used as indicated), such that the speedometer will always show at above or at speed and never below. It is not reprogrammable/recalibrated.
Originally Posted by Lexus
Standard indication (Actual speed) / Acceptable range
(speedometer display)
20 mph / 20.0 to 23.0 mph
40 mph / 40.0 to 43.5 mph
60 mph / 60.0 to 64.0 mph
80 mph / 80.0 to 84.5 mph
100 mph / 100.0 to 105.0 mph
120 mph / 120.0 to 125.5 mph
140 mph / 140.0 to 146.0 mph
160 mph / 160.0 to 166.5 mph
Ascari_2
IS F (2008-2014)
11-15-12 07:55 PM
ohiostate
07-11-12 08:01 PM
kentchoi
Wheels, Tires & Brakes Forum
07-14-05 11:49 AM
DaveGS4
09-03-02 02:15 PM
Quick Reply: Tire size Question
