Another recall? This one for leaking brake fluid in '06 IS
Old 10-21-10, 08:23 AM
suicidesam
suicidesam's Avatar
Old 10-21-10, 08:45 AM
08IS350
08IS350's Avatar
Another Recall. So they are going to drain brake fluid and replace a seal.
I am at 30k and i have to do brake fluid flush according to the service guide. So, if i do recall I don't have to do it anymore and save $$$. Am i right?
Old 10-21-10, 09:04 AM
penone
penone's Avatar
Well, based on your screen name - 08IS350 - I assume you have a 2008 IS350 therefore recall does not affect you. This would only be for certain 2006 models.
Old 10-21-10, 09:39 AM
LexyIS350
LexyIS350's Avatar
The recall may indicate that if you keep with the OEM brake fluid the seal should be fine but if I remember correctly, the manual also states Dot 3 equivalent is fine to use. I could be wrong, I need to look again. I'm guessing it's possible that some of the aftermarket dot 3 doesn't contain this special polymer.
Old 10-21-10, 10:11 AM
edgeucated
edgeucated's Avatar
haha im at 54k! just in time for my 60k brake fluid change
Old 10-21-10, 10:48 AM
hybridanim
hybridanim's Avatar
woohoo another recall. luckily, i haven't taken my car to the dealership to get any of these recall fixed yet. Hymmm maybe i should wait another year until more recalls comes out. Let see, floor mat pedal, cold engine start up tsb, valve springs, and now brake fuel line.
Old 10-21-10, 11:26 AM
revoappare
revoappare's Avatar
For those that have to do a brake flush soon, where can we buy this brake fluid with special polymer?
Old 10-21-10, 11:30 AM
Synetix250
Synetix250's Avatar
Post
i just heard about this new recall on the news this morning..i have to say, this setback definitely isn't going to help toyota in re-building their image since the last recall. hopefully they'll get it taken care of quickly and as quietly as possible. i am still very much happy with my '07 is250 though.
Old 10-21-10, 11:34 AM
trixxx519
trixxx519's Avatar
my warranty expired on my 06...what to do now lol
Old 10-21-10, 11:37 AM
darkdream
darkdream's Avatar
^ Wouldn't it still be covered since it is a recall versus simply warranty work.
Old 10-21-10, 11:38 AM
IS250TW
IS250TW's Avatar
AFAIK its free for all recalls.....
so it doesn't matter if your warranty is expired or not
usually if one did not purchase extended warranty, most of the cars in this recall have expired their warranty
Old 10-21-10, 12:30 PM
rebs
rebs's Avatar
Originally Posted by Kurtz
At a glance this is, like the floormat one, another idiotic recall...
The description I read was that the OEM fluid contains certain polymers that aftermarket fluids might not. If you use an aftermarket fluid without them you might get leakage in the system.
http://pressroom.toyota.com/pr/tms/t...ly-177010.aspx
I agree to a certain extent.
It says in the Owner's manual "FMVSS No.116 DOT 3 or SAE J1703 brake fluid", but my research indicates that you can meet that requirement and not have the "certain polymers" they are referring to???
IMHO they either need to be more specific on their recommendations and/or have a seal that supports a wider variety of OTC brake fluid. Having said that, I'm not a mechanic/service tech, so I'm sure you (and others within this forum) could provide more information on that.
I guess on the plus side, this is another recall that doesn't affect me. I've only been under the "shorter pedal/accelerator override" recall. Yay for late model 2008 builds (at least so far). :-)
Old 10-21-10, 01:23 PM
Micaiah
Micaiah's Avatar
Good Lord.
I'm gonna hear this from my friend who owns a BMW....
Old 10-21-10, 02:32 PM
albis350
albis350's Avatar
jaja me too...hope my dealer already knows about this recall and can go and do both at the same time...the valve spring and the brakes...
Old 10-21-10, 03:41 PM
Lexitegra
Lexitegra's Avatar
So newbie question...if you did not purchase your vehicle from the Lexus dealer (but instead a private party etc), would you still be mailed the recall notices and how would you go about getting the recall work done?
Quick Reply: Another recall? This one for leaking brake fluid in '06 IS
