I'm thinking about adding a radar field disturbance sensor that has a prewarn ... does anyone know if it can hook up in such a way that a prewan will trigger the beeps and flashes like when you press the Lock button?
Did you attempt to add the 508D(radar field disturbance) to your system?
Yes, I did add the 508D but didn't attach to the beeps. If you're going to use the 508D try not to put it next to other sensors, I think it triggers the motion sensor (I covered my tilt sensor with foil :-)
After pricing out a even simple factory system upgrade, I am going to at least attempt this install over the weekend. Its just a much better setup IMO, I hate dealing with all the "extras" a system like viper offers. A simple upgrade seems to be all most people will need.
Can anyone confirm that a 4 pin relay won't have an issue with this install? Looking at the connections it seems like the 5th pin is not really needed.
How many have had this done for their IS? Anyone know if there is a difference between the IS and ISF factory alarm?
I am tempted to do this and im wondering the same thing. I have a 2008 ISF and im guessing it should be the same.
I am ordering the parts to do this and im going to integrate a shock sensor as well. Specifically using the DEI 504 doubleguard shock sensor.
It has 4 wires: Red (positive), black (Negative), green (warning), blue (trigger)... but i think i can connect the blue and green together to the trigger or just use the green so it gives a warning if the car is bumper/touched.
