Question about HID Fog Lights
Hi,
Do you guys have any recommendations on a kit of HID fog lights? (reasonable price and quality). Where can i get it? I'm planning to get 8000k.
Actually, will there be any difference in the color if I use different brands for my low and fog? (same temperature) . Because I installed the low (8000k) already with an unknown brand I got from ebay.
Last thing, I live in Minneapolis MN... I was just wondering if someone know where I can go to get my fog light converted to HID and how much it will cost (approx) for the labor?
Thanks a lot
Thanks a lot
Hi,
Thanks a lot
Thanks a lot
there actually a youtube video to install it http://www.youtube.com/watch?v=k7k7XwaXzhI
http://www.youtube.com/watch?v=BLeB0...eature=related
He already has 8k low, and looking for fog
DIY for sure, and no need to take the bumper off either, try to follow the link below
https://www.clublexus.com/forums/is-...tallation.html
rbudiman, I live in Bloomington and converted both my low and fogs to hid. Holla at me if u need help, local ftmfw mang...
Oh and btw, I'd went with Hidextra (8000k lows and 3000k fogs)...
The HID Fog lamps that I found at some website which also coming with LED was price around $ 2,000. Too expensive for this choice.
You may find another HID fog lamp kit with lower price by search them with google.
Uber 1337 Moderator
It will be VERY difficult for you to get an exact match. There are just so many variables: brand differences, projector lows vs. reflector fogs, age of bulbs, etc. Maybe go yellow? Otherwise it'll probably be trial and error.
As for recommendations, +1 for DDM Tuning or HIDExtra.
Those must be the JDM projector fogs (vs. standard reflector, halogen fogs in USDM ISx50s) you saw, which as you mentioned come with LED DRL's as a cluster to the side of the fogs. I'm sure the OP is talking out simply putting HIDs into his standard fog housings, which could cost as little as $50-$60 for a kit.
so, for the fog lights, I should get the 9006 one right? And how about the wattage? should I get 35W or 55W one?
In their website (DDM tuning), they also offer HID harnesses and error code eliminator, Do I need to get one of those?
Uber 1337 Moderator
Can't say for sure, so hopefully someone else can chime in. I don't believe you need the error code eliminator. I thought most HID kits already come with a relay harness - if the kit doesn't include one, you should probably get one. The relay harness ensures a constant supply of power.
for sure get the 35w or else the extra wattage will melt your fog's housing, unless you have Phillips HID bulb which could be a little pricey. if you're buying it from ddm you will need to buy the relay harness as the kit do not come with it.
quang: and i prefer to my bumper off when i installed mine because i wanted to mount the ballast behind the support beam.
