IS350 cig lighter/12v port not working?
Old 08-25-10, 09:23 AM
rselby
rselby's Avatar
Default IS350 cig lighter/12v port not working?
both of them quit working...the one near the ash tray and inside the console...is it a fuse and if so which one ? I looked but didnt really see any that was blown...sucks cant charge my phone, can any one help..thanks
Old 08-25-10, 09:29 AM
mdsbrain
mdsbrain's Avatar
I blew the fuse in my 12V early on a few times till I found out the charger I had was crap. Check the fuses.
Old 08-25-10, 10:15 AM
shadowman
shadowman's Avatar
Did you check the manual? It should have the fuse mapping.
Old 08-25-10, 12:32 PM
rselby
rselby's Avatar
dont have a manual...could someone tell me what fuse it is...I looked and didnt see any that was blown...but maybe I missed one..took the console apart also..wasnt getting voltage out of the harness to the cig lighter..w
hat is the fuse named that I should check...thanks..charger works n my truck..so its good
Old 08-25-10, 01:21 PM
TokerIS350
TokerIS350's Avatar
Change the Fuse!!!
Old 08-26-10, 11:48 AM
rselby
rselby's Avatar
there is no fuse marked...cig lighter or acc or what ever...so like I said I looked at all of them..didnt see any that was blown....so if someone could tell me what the fuse is called..or marked in the fuse box...or which fuse goes to the cig lighter....thanks
Old 08-26-10, 01:48 PM
ScKcBc
ScKcBc's Avatar
mine is blown too and the dealer wanted $60 to fix it. I passed...
Old 08-26-10, 02:06 PM
rselby
rselby's Avatar
Did they tell you what was wrong with it? Does anyone know how I can fix this problem???
Old 08-26-10, 04:24 PM
SteveTango
SteveTango's Avatar
Default same issue here...
rselby - You can actually find it on Page 296 to 306 of your Manual. The fuse is located at the Passenger’s side instrument panel it's the number '10' on the fuse layout.
Same problem the Cigarette lighter outlet doesn't work on my IS2 and it's annoying when I'm using my GPS because I use the charger inside the arm rest so I have to leave it open when i'm driving.
I haven't actually fix the problem yet too lazy to do it... but if you're up to it let me know how you did it so I could change/fix my fuse too. Thanks!
Old 08-26-10, 09:11 PM
rza8gamma
rza8gamma's Avatar
I had the same problem and found the fuse in the passenger side fuse box under the glove compartment. Pain in the *** to change since I'm right handed...But it uses a "15" mini fuse located in the middle of the fuse box. I have a 2006 so i don't know if it is different in the 09-10's....hope this helps.
Old 08-26-10, 11:28 PM
2slow
2slow's Avatar
I think the cig lighter is not a 12v port. It's specified for the cig lighter. Phone chargers sometimes draw a certain amperage that will blow the fuse.
Old 08-29-10, 08:43 AM
rselby
rselby's Avatar
can someone verify that there is another fuse box under the glove box before I start taking the dash apart...I dont have a manual to look at to see for my self...thanks
Old 08-29-10, 09:41 AM
uz07lex
uz07lex's Avatar
I had the same prob. I will look in the manuel for you but my wire came loose under the lighter and caused a short. Will let you know once i lookin the man.
Old 08-29-10, 01:32 PM
rselby
rselby's Avatar
thanks...would b really b nice to use my phone charger in the car again...
Old 09-23-10, 05:54 PM
rselby
rselby's Avatar
ok I finaly fixed it...was so easy took like 45 sec...there is a lil fuse cover under the dash on passenger side...gotta get in the floor and look up under the glove compartment..and there it was a white fuse panel...just flip it open pull fuse put new n its place...I thought I was gonna have to take the dash apart or something...
The following 2 users liked this post by rselby:
bazzle01 (05-13-17), IS350vue (05-07-17)
Quick Reply: IS350 cig lighter/12v port not working?
