Will those Wheels Fit an IS250 AWD - Part Uno
Old 01-24-11, 04:21 PM
  #46
ald03
ald03's Avatar
im thinking of 19 x 8.5's all around and either road magnet springs or f sport springs....not sure about rubbing and all that good stuff though :/
Old 02-03-11, 10:05 AM
  #47
intrinsic
intrinsic's Avatar
will having the same size wheel but a different offset have a staggered look? like 19x8.5 all around but with +35 up front and +25 out back?
Old 03-31-11, 08:13 PM
  #48
ImBlown
ImBlown's Avatar
This thread is EXACTLY what I was looking for... everyone was telling me that I had to run the same tires on all four corners. Ha! thanks guys
-Joshua
Old 04-11-11, 12:31 PM
  #49
K3mani
K3mani's Avatar
Originally Posted by Tajai7
I'd like to see some pics of peeps running 19s and 20s on AWD that aren't dropped just to see if it looks strange with the huge gap on the AWD model.
Stock diameter is 24.97" (225/45/17)... I keep reading that you shouldn't run plus size tires that are more than 3% bigger than stock diameter tires/wheels (which the max would equal 25.719"). And that AWD models should be running with the same diameters & offsets. Obviously with people running staggered set ups on the AWD, this standard has been debunked if the difference is close. I'm curious if the max of 25.719" is a myth too. What is biggest diameter you can run without cutting/modifying the wheel well (say I am running 19s or 20s that are 8" or 8.5" wide as I know the width would make the difference in rubbing when the wheel is turned)? I'm basically looking for the biggest wheel I can get without a drop on an AWD. Thanks.
(245/35/19 = 25.75"; 245/30/20 = 25.79") (source: Tire/Wheel Combination Calculator)
Hey, what offset did you use for Front & rear? What tires & wheels are you using? Post some pics if you can, because I am about to do the same thing (thinking about lowering 1" later on) and wanted to know how it looks.
Thanks!
Old 04-11-11, 01:18 PM
  #50
Tajai7
Tajai7's Avatar
Default Wheels for AWD
K3mani -- I'm still rolling stocks. Still waiting for people to post pics and info that are non-staggered w/ no drop. My biggest concern now is offsets. Stock AWD offsets are 45mm all around...not sure if we can get away with different offsets in the front and back or if it would potentially mess something up, or can we run the same offsets all around that are less than 45mm?
Old 04-11-11, 07:12 PM
  #51
K3mani
K3mani's Avatar
I have the same questions, but to be more specific:
1) Until I lower the suspension, what are the max wheels/tires (non-staggered & staggered) that can be used without rubbing?
2) What affects does lowering have on performance, gas mileage, etc...? Or does it only affect handling, noise & comfort?
3) Has anyone already dropped their AWD with coilovers? If so, can you fill me on the basics (price, required parts, best brand, etc..)
I appreciate all the help in advance. This forum is great! If a vet can give me a crash course on this, I would really appreciate it. I'm an old 1998 Accord moder looking to really modify my new lexus without sacrificing stock performance too much.
Old 04-13-11, 06:38 PM
  #52
TriggrHapy
TriggrHapy's Avatar
Hi all, same delema as a lot of AWD drivers... so hopefully I can find some answers. Unfortunately for you I do not have answers!
Bought 2011 IS 350 and am looking to replace the weak OEM 17"... So I am thinking of what I need to do to get a nice flushed look for either 8.00 or 8.5" rims. I am assuming that given the stock 8" rims are 45mm that an 19"X8 after market can go down to 35mm offset on the front and by a lot more in the rear as the body is built for a staggered set-up.
I am not going to get staggered so will probably address the front to rear offset discrepency with spacers (15-10mm added to the rears.)
Ride height will be lowered by 1" with f-sport springs...
Old 04-18-11, 03:57 PM
  #53
DaXxJaPxX
DaXxJaPxX's Avatar
lookin to run 20x8.5 30mm 245/35/20 front and 20x10 38mm 285/30/20. diameter difference is only .08%, but my question is will this fit and not rub?
Old 05-04-11, 04:28 PM
  #54
SILVRLININ
SILVRLININ's Avatar
^1+ on that question. What fender mods would be required if im lowered on 20's ???
Old 05-05-11, 02:42 PM
  #55
DaXxJaPxX
DaXxJaPxX's Avatar
just put on 20x8 +40 on 225/35/20 all around. Very slight rubbing on front left wheel, nothing a lighter cant fix .
Old 05-11-11, 05:53 AM
  #56
netsrac
netsrac's Avatar
Nice set-up, FYI when your speedo reads 65 MPH, you are actually going 68 MPH
Old 06-02-11, 04:05 PM
  #57
sleekbrian
sleekbrian's Avatar
Front-19x8.5 +30 with 235/35/19
Rear-19x10 +38 with 275/30/19
I know this setup will work, but if i lower it with BCR coils for a conservative drop nothing crazy will i rub or need to roll my fenders?
Old 06-02-11, 04:58 PM
  #58
laobo979
laobo979's Avatar
Sleek it all on how low you go. You might say conservative then later on you might want no wheel gaps.
Old 06-02-11, 08:26 PM
  #59
sleekbrian
sleekbrian's Avatar
Yea thats what i thought, what height can i get away with without rubbing?
Old 06-09-11, 03:20 PM
  #60
jbounnoi
jbounnoi's Avatar
is any body running
F - 225/30-20 OD=25.31
R - 265/25-20 OD=25.22
Difference of -.09
wondering if its fine or not..
Quick Reply: Will those Wheels Fit an IS250 AWD - Part Uno
