Will those Wheels Fit an IS250 AWD - Part Uno
Old 09-20-12, 11:13 PM
  #166
S2KIS250
S2KIS250's Avatar
just bought some winter tires to mount on the stock 07 AWD 17's. the closest size they made in the tire was 215/50/17. i know the overall circumference should be fine, i'm just worried about mounting the 215's on the 8" wheel. does anyone know if this is going to be an issue at all?
Old 09-26-12, 11:15 AM
  #167
sm1ke
sm1ke's Avatar
Shouldn't be an issue. I had 215/45/17 on my old 17" summer rims and they had a very minor stretch. You could barely tell. 215/50 should be fine.
Old 10-08-12, 05:40 PM
  #168
silvaIS
silvaIS's Avatar
Here are my choices for wheels. I want to put tires on them and be able to do tire rotations back to front, so i think they need to be the same size all around. Whats my best option if I go with 18's or 19's in those regards.
Avant Garde M310 in Dolphin Grey
Sizes:
18x8.5 5x114.3 +35
18x9.5 5x114.3 +40
19x8.5 5x114.3 +35
19x9.5 5x114.3 +40
Old 10-09-12, 06:32 AM
  #169
Carbonsrt
Carbonsrt's Avatar
Will a 18x9.5 +25 with tire size 225/40 fit on our AWD lowered with H&R springs?
Old 10-09-12, 06:59 AM
  #170
MarkFaul
MarkFaul's Avatar
I need some help.. I have read through the first couple pages but still have some questions. I just bought an 08 and it has 17 inch wheels. I found someone local selling the 18 inch stock wheel for like 250 (i think thats a good deal). I was wondering what tires i can put on them? I want to fill out the wheel well more but I don't want to lower the car and don't want to the speedo to be affected. Does anyone have any picture of stock suspension with the 18 inch wheels? I
Thanks
Mark
Old 11-07-12, 10:23 PM
  #171
ChiCityG
ChiCityG's Avatar
Originally Posted by soleeasii
I just got my front Diff and driver axel replaced at 37k miles.. wheels were put on at about 18k.
I was running 235-35-19 and 265-30-19.
Could you explain more? It seems this would have been within spec of rotational diameter... Did they explain this staggered setup as the cause for your front diff and axel going???
Old 11-07-12, 10:28 PM
  #172
ChiCityG
ChiCityG's Avatar
Also, if I were to pick up a set of wheels that were 19x8 f and 19x8.5 rear, would it be more accurate to just run 235/35 tires all around on this setup since it is so little of a difference or would it still be better to run 225/35 f and 265/30 r ???
Please, any help will be much appreciated!
Old 11-08-12, 01:31 PM
  #173
ChiCityG
ChiCityG's Avatar
Bump... Any thoughts?
Old 12-05-12, 06:31 PM
  #174
AhMeTaPoo
AhMeTaPoo's Avatar
Hey im looking into some work vs-xx... question is what kind of specs should i run for 19's on coils or i might go with 18's with rm springs just need to know the right fitment
Old 12-05-12, 07:13 PM
  #175
is250smk
is250smk's Avatar
Hello,
Can someone tell me if these winter tires will fit my 07 Is250 awd. I am getting them w/wheels for free if they will work. Wheel bolt pattern is 114.3 x 5 50 mm offset. looking on sites it appears the wheels will fit. The tires are 215/55 r17. Will the tire height be too high and rub?
thanks
Old 12-13-12, 10:57 AM
  #176
agarciagmu
agarciagmu's Avatar
Default need help
Will this setup fit a 2006 is250AWD on f-sport springs?
20x9 +35
20x10 +40
tires:
hankook ventus v12 evo 225/30/20 (front)
advan sport 245/30/20 (rear)
Old 12-13-12, 11:03 AM
  #177
sm1ke
sm1ke's Avatar
^^ Yes it'll fit. How will it look, will it rub, etc.. these are questions that can only be answered by people with experience. What's unfortunate is that these people seem to avoid this particular thread like the plague.
Old 12-23-12, 07:02 PM
  #178
AhMeTaPoo
AhMeTaPoo's Avatar
You guys think i can run this on a 2006 lexus is250 awd drop on bc coils, trying to buy em before there sold from a cl member and if anyone can give em tires specs would be helpful.
F 19x8.5 offset 38
R 19x10 offset 43
Old 12-29-12, 07:15 PM
  #179
kwikshift
kwikshift's Avatar
F 19x8.5 offset 38
R 19x10 offset 43
That works and are you looking for the stretched look or more of a beefy setup?? That will determine your tire size.
Old 01-03-13, 11:12 AM
  #180
br3akenout
br3akenout's Avatar
Could i make these work? Someone is selling and I really want them but can only do it if I can make them work obviously.
5 x 114.3
19 x 8.5" , +22
19 x 9.5" , +25
Quick Reply: Will those Wheels Fit an IS250 AWD - Part Uno
