Car wont start / no ignition
Old 07-21-10, 02:37 AM
sveinongen
sveinongen's Avatar
Cleaned the corrosion now, same problem. I may have destroyd something when i shorted the plug for the brake fluid reservoir, but I cant understand that it should break something when just shorting a plug, Isn't it just an On / Off switch in the Brakefluid reservoir?
Anyway, got the price for a new ECU 1200$
Anyone know if it's plug &play or does it have to be calibrated/programmed?
Dont know for sure that the ecu is the problem but it's EXPENSIVE to bring the car to a workshop here in Norway
Old 07-21-10, 07:20 AM
Jetfire
Royale with cheese
Jetfire's Avatar
you don't have warranty anymore? i think it's better to diagnose the problem rather than buy an ecu and hope the problem gets fixed.
Old 07-21-10, 10:00 AM
MIA_LEX
MIA_LEX's Avatar
What were you doing to the brake fluid reservoir that made is short something out?
Old 07-21-10, 10:15 AM
sveinongen
sveinongen's Avatar
No warranty, car is 4 years old, The probles is, that you cant diagnose without getting power to all of the ECU's in the car, i have tools to diagnose with but I cant get Ignition on. only thing I that powers up is the Nav screen
Old 07-21-10, 10:17 AM
sveinongen
sveinongen's Avatar
The problem starte with the handbrake warning light, then we tried to short the connector to the brake fluid reservoir, then the light disapeared, but when i stopped the car and tried to start it again nothing happend.....
Old 07-21-10, 10:25 AM
shadowman
shadowman's Avatar
I'm not sure how far you live from dealership, but it might be worth a shot to tow it to lexus dealer for diagnostics. They have computer diagnostic equipment to read the engine codes and what errors are going on. Then you can bring your car to a cheaper mechanic if you want. It sure beats buying a new ECU when there is another thing that was wrong.
Old 07-21-10, 10:31 AM
MIA_LEX
MIA_LEX's Avatar
This sounds awful goodluck with fix!
Old 07-21-10, 10:45 AM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Did you try disconnecting the battery????
or resetting the ECU ??
Joe Z
Old 07-21-10, 01:04 PM
sveinongen
sveinongen's Avatar
Please read my post's,
I have diagnostic tool but I cant get ignition on so none of the ECU's get power, so it's then impossible to make a diagnose or read Error codes.
Old 07-21-10, 01:05 PM
sveinongen
sveinongen's Avatar
Joe Z
Hi, yep battery have been disconnected and recharged.
by resetting ECU du u mean removing Relay's?
Old 07-21-10, 02:06 PM
Joe Z
Joe Z's Avatar
No there are 2 Ignition fuses in the engine compartment fuse box..
BUT if you disconnected the battery already... it was done...
Jz
Old 07-21-10, 03:52 PM
sveinongen
sveinongen's Avatar
Jz
okidoki..
Old 07-21-10, 04:20 PM
llamaboiz
llamaboiz's Avatar
wait... so you had the handbrake warning lite on so you thought instead of getting it checked out better to short it out just to get rid of the lite? now the car is pissed at you and wont let you start her? im sorry but this is kinda funny, sux2bU...
i gotta thank you, we all learned from your mistake.
Old 07-21-10, 05:05 PM
sveinongen
sveinongen's Avatar
Yes because they could not se any problem when they checked it with the Intelligent Tester..
The warning light whent off every time we shorted it, but when I tryed to start the car again nothing happend.
Old 07-21-10, 05:15 PM
shadowman
shadowman's Avatar
From my dealer:
You can't use a standard diagnostic tool on a Lexus. To get the proper codes, you basically have to take it to Lexus. A Lexus Diagnostic System cost $150,000. I doubt any normal person can fork out that much.
... or my dealer is BSing me.
Was your diagnostic tool working before the ECU issue?
Quick Reply: Car wont start / no ignition
