NAVI issues! touch screen not working!
Old 07-19-16, 01:07 PM
  #61
Gville350
Gville350's Avatar
Darryl still offers his services via ebay. He has done quite a few of our members NAV units on here. I even talked to him about doing mine; but I found a used, local NAV unit to replace my bad one.
http://www.ebay.com/itm/182198724302
Old 08-23-16, 08:07 PM
  #62
dragonphp
dragonphp's Avatar
I just fixed the frozen screen on my IS350 recently. $50 total...
Video with instructions:
Old 06-25-17, 10:26 PM
  #63
maz
maz's Avatar
So my touch screen stopped working today after 10.5 years of owning my '07 Lexus (Oct 2006 purchase date). When I press on the screen, the map just moves to the right. Based on my research, the digitizer is broken. So I'm going to buy a digitizer from eBay for about $24 and try and replace it myself. This is likely a heat related issue as it has been scorching hot here in Texas. Just a couple of days ago, my car was displaying 115 degrees for the outside temp, the hottest I have ever seen it. I do wish Lexus had made these sturdier or had issued a recall notice as it seems to be a pretty common problem. I'm still getting recall notices for other problems and this should have been one too.
Old 06-26-17, 05:44 PM
  #64
Gville350
Gville350's Avatar
Lexus didn't make the LCD screen components. I believe it was Toshiba. If the new digitizer doesn't work out for you, you can always replace the entire screen, which includes a new digitizer.
Old 06-27-17, 02:24 PM
  #65
andrewwake
andrewwake's Avatar
Amazon Amazon
Only $36 currently. I bought mine a couple years ago for $44 from Amazon. It's still working and a hell of a lot cheaper than buying a whole new head unit, which is what Lexus says you have to do at $1,200.
Old 06-28-17, 12:14 PM
  #66
whitebeast
whitebeast's Avatar
The whole new unit at dealership is around $5k
Old 06-28-17, 12:17 PM
  #67
whitebeast
whitebeast's Avatar
you are right, toshiba make LCD and built NAV unit for Lexus as well.
Old 07-01-17, 11:10 PM
  #68
maz
maz's Avatar
Disassembled the enitre NAV unit today and removed the old digitizer (a very challenging task), then I put on a new digitizer I got from ebay advertised as being for the 2007 Lexus IS, 7.3". It fit perfectly, the touch issue is now resolved, but there is a terrible rainbow effect. After reading some reviews, it seems this is a common problem with some digitizers. Has anyone had this problem? Is there a way to fix it, like by placing a special screen cover over the screen? Or is the only solution to find an OEM or closer to OEM digitzer.
Old 07-02-17, 09:43 AM
  #69
whitebeast
whitebeast's Avatar
Most of them will have rainbow effect. However, some of them won't have that problem but I don't know the seller name. Is your as bad as this one?
Old 07-02-17, 10:25 PM
  #70
maz
maz's Avatar
Yes, mine is just like that. The screen is much harder to see especially in the sunlight. I am currently looking to replace it.
Old 07-02-17, 11:05 PM
  #71
maz
maz's Avatar
The seller on Ebay is telling me that I left one of the protective covers on. I can't recall if I took both of them off or just one. Is it possible that leaving a cover on would cause this effect? It's gonna be a pain to open it up again.
Old 07-03-17, 12:51 AM
  #72
whitebeast
whitebeast's Avatar
nope, when i see it on my customer car, i was thought samething to but turn out he did remove the film on both sides
Old 07-03-17, 12:52 AM
  #73
whitebeast
whitebeast's Avatar
the real problem is they are using some kind of clear (cheap) plastic causing this effect
Old 07-03-17, 12:58 PM
  #74
maz
maz's Avatar
You are probably right. I will order a non-rainbow digitizer before I take everything out again.
Old 10-01-17, 07:50 AM
  #75
Bigham
Bigham's Avatar
Default 2007 lexus is350
Hello everyone,
My navigation screen suddenly went full white. All the buttons and radio still function. And when I touch the screen it gives me feedback and makes the sound that I'm clicking something. But the screen just stays blank white and I can't see anything. This is a 2007 Lexus IS350. Any ideas?
Quick Reply: NAVI issues! touch screen not working!
