Will those wheels fit? START HERE.
Old 07-11-07, 06:12 PM
  #106
bwoodwrd1
bwoodwrd1's Avatar
A 25mm in front is pretty aggressive. And as for a spacer, remember it subtracts from the offset, not adds to it (so you are looking at a 20mm offset with a spacer.) A 10" in back is doable, others have done it, but you might rub. You will probably have to roll your fenders.
Old 07-23-07, 04:20 PM
  #107
royal5fan
royal5fan's Avatar
Default Volk wheel question
I have finally settled on a set of SF Winnings (since I can now use the iforged adaptors for the TPMS) but I have a question. On the Rays website, they list a 19x10.5 that I would like to use in the rear but I dont know if it will fit. I saw in the wheels thread that Titus350 had stuffed a 10.5 HRE in the rear but he didnt know the offset. Anyone have any thoughts on this?
Old 07-23-07, 04:49 PM
  #108
solo_stage
solo_stage's Avatar
im pretty sure 10.5 shouldnt be a problem but you need to go with an offset of probably around +45 or +50 i would think?
Old 07-23-07, 04:50 PM
  #109
solo_stage
solo_stage's Avatar
because i currently have SF winnings on my car right now 19x8... and the offset is +45 and i think i need spacers of about 15MM to make it flushed with the bumper in the rear.
Old 07-23-07, 04:56 PM
  #110
iSuxeL
iSuxeL's Avatar
You should be able to run 10.5 with the correct offset.
Old 07-23-07, 07:47 PM
  #111
royal5fan
royal5fan's Avatar
I appreciate the thoughts guys. Does anyone else concur with solo on the offset needing to be +45 of +50 to work?
Old 07-23-07, 08:10 PM
  #112
neova
neova's Avatar
Awhile back another member had a breakwater blue IS350 with custom CPW forged rims and lowered on Eibachs (browse thru the aftermarket wheel thread for pics). I pm'ed him for the specs and here's what he gave me
F19x8.5 +38 235/35R19
R19x10.5 +55 285/30R19
He noted that the 10.5 must require +50 if you plan to use 275 wide tire and above. At +55 with 285 tire there's minimal clearance between the tire and the fender and also between tire and the suspension. Mind you another member had 10.5 with 295 tire but I assume he may be cutting very close to rubbing when the suspension goes into full compression.
Good luck with your wheels and post pics when you're done!
Old 07-23-07, 09:11 PM
  #113
royal5fan
royal5fan's Avatar
Thanks neova, this is exactly what i needed. I had seen the pics of the breakwater 350 on CCWs, they are very nice. The member running 295 in the rear is Titus350. He is on HRE wheels. I will pm both to see if they are having any rubbing issues.
Old 07-23-07, 10:02 PM
  #114
cdeeznuts
cdeeznuts's Avatar
hey let me know what part to get from iforged for the adapters. need to take the wheelbarrow wheel out of my trunk.. haha
Old 07-24-07, 09:13 PM
  #115
royal5fan
royal5fan's Avatar
I will let you know if the adaptors work. We are going to look like identical twins. What size wheels and tires are you running?
Old 07-27-07, 05:11 AM
  #116
arrior
arrior's Avatar
Default offset question pls help..
hi...can anyone help me if a 235/18/40 18x8.5 +50 offset all 4 wheels fit the is350?will the offset of +50 be ok in the front?thanks
Old 07-27-07, 06:54 AM
  #117
AZ IS350
AZ IS350's Avatar
They'll fit all right at the +50 offset, but it won't look any better than the stock 18" wheels do, as far as being flush goes, and probably look worse. If you want them to look more flush, go with a lower offset. If you want to keep the same size wheel/tire front & rear, I'd suggest maybe something around +35 offset.
Old 07-27-07, 09:20 AM
  #118
t0e
t0e's Avatar
Might not clear the Big Breaks...
Old 07-27-07, 09:26 AM
  #119
al503
al503's Avatar
I have 235/40/18's on an 8.5" wheel with a +40 offset and I can squeeze my pointer finger between wheel and the spindle. If you reduce that by 10mm, you're going to rub. The MINIMUM I would go on the offset with a 8.5" wheel is +45.
If you have the stock 18"s, put the rear wheel (8.5" +50 offset) on the front. It won't work as I tried it when I was trying to figure out the best offset.
Old 07-27-07, 12:24 PM
  #120
arrior
arrior's Avatar
is it the same with the 250?
Quick Reply: Will those wheels fit? START HERE.
