Will those wheels fit? START HERE.
04-01-10, 10:53 AM
post some pics after you got the wheels...
04-01-10, 11:13 AM
That setup looks nice
04-01-10, 02:17 PM
how much do these rims cost??? i plan to buy them when i get my car in may. is350 ftw.
04-01-10, 02:43 PM
^^^ Bump! Another set off g35driver I found is:
19x9.5 +19 2.5" lip245/35 tires
19x10.5 +17 4" lip 295/30 tires
Will this work? Anyone Anyone? lol
04-01-10, 02:47 PM
Quote:
Originally Posted by
jav@vossen
hey.. you should run a 19x8.5 +32 (235-35-19) and 19x10 +38 (265-30-19 or 275-30-19). They will fit perfect and flush.
Any rubbing with those offsets? What about if the car is dropped on coils to remove the wheel gap?
04-01-10, 03:09 PM
I am no wheel expert, that those are damn aggressive sizes/offsets.
04-01-10, 03:49 PM
Royale with cheese
brociouz
any rubbing lowered to remove gap from tire and fender on coils? not looking to slam or to roll/cut fenders.
04-01-10, 04:09 PM
Those are pretty agressive, I'm sure you can make the wheels fit but it will take a lot of work and some fender pulling, and those tires are way too big.
04-01-10, 05:23 PM
what are good offsets for the AWD if you were to run 18x8 or 18x8.5??
04-05-10, 10:33 AM
Help/Advice for wheel fitment
Hello guys. I recently purchased a set of wheels and was rubbing in the front. The front set up is 19x8.5 +53 with 235/35 size tires. It wasn't rubbing on the fenders but in the shock area. I put on a 5mm universal spacer to get rid of the rubbing for now but I don't want to keep that universal spacer on. I was thinking if 225/35 tires would stop the rubbing inside or buy the hub centric spacers to clear it. Thanks!
04-05-10, 10:41 AM
its because its a +53, its too high of an offset for and 8.5
04-05-10, 10:52 AM
Mv350
Would 225/35 tires would still rub? I mean spacers would help clear it but I'm trying to avoid using spacers but it is leaning towards using them.
04-05-10, 10:56 AM
Frosty250
Your offset are too high, you're going to have to use spacers no matter what. If you go 225/35, on bigger dips you will rub again.
04-05-10, 11:19 AM
Sytfu_IS
Would 5mm hub centric spacers require extended studs or it will work with stock studs?
04-05-10, 11:22 AM
Fellow newb. here.. Just purchased some new wheels,(F)19x8.5 (R)19X9.5 OFFSET are, +30 front and rear... Im sure i could use 225/35/19 for the front, how about for the rear what tire size should I use?
thanks in advanced.
