Will those wheels fit? START HERE.
Old 02-26-10, 04:01 PM
  #796
DasNutz
DasNutz's Avatar
Originally Posted by pchan0
1/2' is 12mm but that applies to both side of the barrel, so 6mm on one side. eg. 8.5' +24 in 9.0' will be +18
Even though it's just the front barrell I will be replacing?
Old 02-26-10, 04:05 PM
  #797
DasNutz
DasNutz's Avatar
Originally Posted by mdgrwl
+1 ^^ you would be running +18 offsets which will probably rub without MAJOR fender mods...
I'm running +20 all around right now on my 19s 8.5 and 9.5 without rubbing issues right now. I already did some fender mod like rolling
Old 02-26-10, 04:11 PM
  #798
mdgrwl
mdgrwl's Avatar
okay... so get your story straight! lol.. your first post states both front and read...
okay so just apply the +18 to your front wheel then
regarding bumping up your 18" to a 20"... just think and visualize it. pull up the tire mfr site and compare the tire sizes (because 20's are larger then 18's)
its a mm game. - use your judgment.
my IS may be a few mm's off then yours... our fender wells, our camber... there's so many factors
it seems you know what your talking about so bust out the calculator and do the math...
Old 02-26-10, 05:59 PM
  #799
DasNutz
DasNutz's Avatar
it seems you know what your talking about so bust out the calculator and do the math...[/QUOTE]
WOW I wasn't trying to **** anybody off here. I might have forgot to mention that I use to have 19's then jumped to 20's then now I have 19's again but I could not pass up the deal on these 20's so I got em. I have experimented with spacers on my old staggered 20's so I know how or what limits I can go the mere question I had was of the offset after putting onnew barrells. Your probably right that our fender mods wheel offsets are mm apart so I give you credit on your knowledge but it doesn't give you any right to talk to someone assumming that they don't know sh@t, know what I mean so if you want to please reread the explanation on the first post I would really appreciate it, I would rather stick to the topic then leading into a debate on who has the bigger hummmmmm!!!! Thanks for all that has responded positively.
Old 02-26-10, 06:03 PM
  #800
DasNutz
DasNutz's Avatar
Here let me reitterate my statement maybe this is where you got confused. On a 3 piece wheel you have a front barrell which is the lip then the face of the wheel then the REAR barrell I'm still only talking about 1 wheel.
Old 02-27-10, 07:09 PM
  #801
dubsesd
dubsesd's Avatar
Default offset question
would 19x9 et47 be a problem? any issues with rubbing in the front. probably gonna run a 235/35. found a deal on these....
Old 02-27-10, 07:14 PM
  #802
ilv1004s
ilv1004s's Avatar
Default How much offset or less offset do i need?
okay found a set of 20x9.5 38 offset for the rear would that be close to flush ?
or would i better off going for 20x10.5 with 38 offset in the back? and use the 9.5 ins the front?
Old 02-27-10, 08:03 PM
  #803
dubsesd
dubsesd's Avatar
quick p-shop...kinda reminds me of the oem lobsters
Old 02-27-10, 09:48 PM
  #804
Pnuge88
Pnuge88's Avatar
9.5 up front 10.5 in the rear with those offsets to be more "flush"
Old 02-27-10, 10:16 PM
  #805
iRock
iRock's Avatar
Will 9.5 fit up front with out rubbin?
Old 02-27-10, 10:34 PM
  #806
ChrISF
ChrISF's Avatar
best bet is to try it out on your own
Old 02-27-10, 10:37 PM
  #807
ChrISF
ChrISF's Avatar
nope.
Old 02-28-10, 01:47 AM
  #808
ilv1004s
ilv1004s's Avatar
hm.. i guess i should try it
Old 02-28-10, 05:35 AM
  #809
dubsesd
dubsesd's Avatar
Cool. Just wondering if the extra 0.5" on the inside would cause any problems.
Old 02-28-10, 11:16 AM
  #810
kevetard
kevetard's Avatar
post a pic when you get these mounted, im interested to see how they look
Quick Reply: Will those wheels fit? START HERE.
