Will those wheels fit? START HERE.
#5296
Correct 8.5 in front (if I decide to go with different widths). You're running 8.5 in front or 8.5 all around? What tire size are you running? Also, where did you manage to find a 42 offset?
#5297
8.5 front and 9.5 rear. Enkei rpf1. 225/35zr19 front and 255/35zr19 or 255/30zr19 in the rear
#5298
Hi guys,
I am looking for some help on tire sizes for my wheels. First off i have velgen vmb5 20 inch wheels 20x9 +35 and 20x10.5 +45. I noticed everyone is stretching a 235/30/20 on the front and 255/30/20 on the rear when dropped down with zero clearance between the fender and the wheel. I am not looking to go that low and would like a little more rim lip protection from the tire especially since i have this much in the set of wheels and the streets arent exactly perfect. I have a set of 255/30/20 and 285/30/20 and was wondering if i could use these tires without any rubbing. I am ok with modifying my fenders if i need to. I would also like to lower my car at some point but i dont want it slammed. One more question i have is how low can i go with out getting longer adjustable camber arms for the rear? Thanks
#5300
Almost all 17" rims will fit. 17" is the OEM size. But it depends on which tires you get.
Geberally, anywhere close to 255/35/17 will fit the front and 275/35/17 will fit the back. Also around +35 offset. Unless you go something extreme or super slammed and max camber when lowered. You won't have any problems.
#5301
Hi guys,
ooooh. This is a close call. Personally, I don't think it will clear. I have 245/35/19" +35 on front and 265/35/19" +35 on rear and I have my fenders rolled. I am also lowered in coils but not aggressively. Your setup adds almost +1.5inches more than mine. If you're not lowered and running OEM height, you might clear but it's a close call.
#5305
Originally Posted by tresfitty
Cosmis racing 18x10.5 +20 all around for 350 rwd
