Will those wheels fit? START HERE.
Old 05-22-14, 08:04 PM
  #5011
InThaMakin
InThaMakin's Avatar
Originally Posted by InThaMakin
Will this fit on 06 IS350?
Also any recommendations on tires?
18x8.5 +30 (3in lip)
18x10 +25 (4in lip)
Planning to drop on H&R or Tein S.
Thanks
http://www.ebay.com/itm/18X8-5-18x10-25-STR-514-5X114-3-GUN-METAL-RIM-FIT-LEXUS-IS250-IS300-IS350-GS300-/400700115903?pt=Motors_Car_Truck_Wheels&hash=item5d4b968bbf&vxp=mtr
These are the wheels im talking about...
Old 05-23-14, 06:11 PM
  #5012
Cisco360
Cisco360's Avatar
I just purchased a 2011 IS250 AWD and hate the way the factory 17" set up looks on the car. I am going to buy a set of the 08 hyper silver five split spoke staggered wheels. I want to run the same rolling wheels diameter. Need some advice on what's the best tire size combo to go with to ac polish this task.
Old 05-23-14, 07:40 PM
  #5013
Reeladdict
Reeladdict's Avatar
Default 2014 is350 AWD will these fit?
2014 is350 AWD.
19x8.5 +30mm
19x10 +38mm
I am not planning on lowering it. If I do it will be with rsr downs, not super downs.
What do I have to do to make them work? What tire size?
Thank you!
Old 05-23-14, 08:06 PM
  #5014
heyarms
heyarms's Avatar
So much misleading info in this thread lately.
People should really do their own homework by finding actual fitment pics on the forum for specs around what they're looking for... Some of these responses make me cringe knowing someone is trusting it!
Old 05-24-14, 06:26 PM
  #5015
DonLex123
DonLex123's Avatar
I believe I should not have any issues based on what I've read in older forum posts but just making sure. I do not want to roll or cut fenders.
Vehicle is a 2006 IS250:
Stance SC5 Wheels- 19x8.5 (35mm Offset) Front
19x9.5 (40mm Offset) Rear
Continental Extreme DWS Tires- 235/35/19 Front
275/30/19 Rear
60.1mm to 73.1mm Aluminum hubcentrc rings
Would be dropping vehicle on H&R Springs and F Sport shocks (Possible Sustec Pro five or BC coil overs in the future...Depends on how car feels and looks on the above springs and shocks).
Old 06-01-14, 12:23 PM
  #5016
sbsc300
sbsc300's Avatar
.I have a 2012 IS250 F-Sport and will be lowered on RSR Sport I Coilovers. Will Work Emotion CR Ultimates fit in a square setup using 18x9.5 +38offset rims wrapped in 245/40/18 Yokohama S-Drive Tires without any rubbing on the fender or on the inner fender liner? Also, will the suspension setup clear when the tires and wheels are at full lock? I've tried searching for days and have yet to find another vehicle with the same setup I want to run. Thank you.
Old 06-01-14, 11:44 PM
  #5017
vcept
vcept's Avatar
I am thinking about having a track set-up for Enkei Rfp1 17".
Does anyone know if a this particular 17" rim will clear the caliper for IS350?
Also would 17x8 plus a meaty tire set-up be possible too?
Old 06-03-14, 09:11 PM
  #5018
InThaMakin
InThaMakin's Avatar
Will varrstoen es3 (18x8.5 +35 front) (18x9.5 +30 rear) fit on a 06 is350 as in clearing the caliper. Will be dropped on h&r. Do you guys think I will need any fender mods or will it rub. Tire recommendations too. Thanks
Old 06-06-14, 09:10 AM
  #5019
SoSickG35
SoSickG35's Avatar
i think i need help guysssss LOL what can i do to make this work
Old 06-06-14, 09:50 AM
  #5020
sm1ke
sm1ke's Avatar
Why anyone would do this is beyond me. But that's not the point.. You'll need a lot of negative camber, and an aggressive roll/pull. There will be guaranteed bodywork because the paint will crack, so overfenders might be a better option. Be careful about rubbing the shock body with the wheels when adding negative camber. You might have to add a spacer if you run into that issue.
Old 06-06-14, 10:17 PM
  #5021
laobo979
laobo979's Avatar
Any thing will work if your willing to do the work. List the spec of the wheels. By the way figs is making a front upper A arm that will go -4 if you wait for it. It's still in the testing.
Old 06-07-14, 01:45 AM
  #5022
OKCIS
OKCIS's Avatar
Maybe someone can answer this for me there so much info and numbers in this thread it just confuses me worse.
IS250 RWD what is the largest 19 inch wheel i can run car lowered to a 0 finger gap but no tuck fenders rolled but no pull and very little camber and id prefer not to stretch my tires but i will a little big if i really have to
With that info whats my max size for as big a lip or concave as i can get? Im guessing like in the rear probably a 19x9.5 +33? can i get it to +25?
Old 06-09-14, 01:39 AM
  #5023
Fran96
Fran96's Avatar
That's easy for you to say AFTER you knows the "in's & out's of this site, as I 'FAQ'd' and did a search for something as basic as installing, and removal of interior ( SC400), and NOTHING comes up....But don't believe me, just do a search...and 'Butcus' comes up....but level with me, am I expecting too much when doing a Search....or is there a type of code to get that info. I "fell" into a partial thread ( of interior removal ) because a member wanted to remove wood and paint it black -for later model look, and the members, when they can be reached- on a specific topic- are ULTRA Helpful, and Great, a real "comradeship"....and the member that was very helpful, said, basically " I could go into more detail about removing part of interior, BUT that's been posted here a million times ( so he abbreviated the details I needed -because doing a search, for something posted "a million times" doesn't come up with anything....it seem's like the Classic " You can't get to there from here" routine. What's the secret ??
Old 06-12-14, 01:56 PM
  #5024
CMACE23
CMACE23's Avatar
08 IS250 RWD 18x8.75 front and 18x9.75 rear. Any suggestions on tires? The car is lowered about 1.25" (M2 junk springs previous owner, coils are otw)
Thanks for the help
Old 06-19-14, 01:15 AM
  #5025
metaleckz
metaleckz's Avatar
need help
what do i do to make the varrstoen es6 fit?
Rim Width:
FRONT 9.5/ REAR 11
Rim Diameter:
19
Offset:
FRONT +22 / REAR +25
thanks!
BG info
09 is350
lowered on bc racing coilovers with 1 finger gap
Quick Reply: Will those wheels fit? START HERE.
