Will those wheels fit? START HERE.
Old 02-27-13, 02:37 PM
  #4321
SoSickG35
SoSickG35's Avatar
Originally Posted by RVCAis250
Won't fit without adding additional camber with a camber kit or wide body fenders.
THANKS AGAIN RVCAis250!
Old 02-27-13, 04:57 PM
  #4322
ScoobyLai
ScoobyLai's Avatar
Is anyone running the XXR 521 18x8.5 +25mm on a 4? I am trying to see how they fit and look.
Old 02-27-13, 04:59 PM
  #4323
supra925
supra925's Avatar
good thread
Old 02-27-13, 05:07 PM
  #4324
supra925
supra925's Avatar
nice thread
Old 02-27-13, 05:10 PM
  #4325
supra925
supra925's Avatar
Thumbs up
Old 02-27-13, 05:11 PM
  #4326
slownlow07
slownlow07's Avatar
Will this size fit and what kind of mods would I need to make to make it fit?
Rim size: 19x10 et 38
Tires size: 265-30-19
Old 02-27-13, 05:52 PM
  #4327
projectdna
projectdna's Avatar
Originally Posted by ZNation
-pic snip-
This is my car on stock 17s
So as a refresher, I'm wanting to put on the following:
Front 245/40/18 on a 9.5" wheel +30
Rear 265/40/18 on a 10.5" wheel +30
Thoughts? Fender rolling required?
i'd go w/ 235/35-18 + 265/35-18.
from your pic it looks like it may not need fender rolling, but i would plan for it to be on the safe side.
Old 02-28-13, 03:52 AM
  #4328
ZNation
ZNation's Avatar
Thanks for your input!
Old 03-02-13, 11:30 AM
  #4329
Scless
Scless's Avatar
18x9.0 5x114.3 30 Offset all around Rota G-Force Concave Rims XXR
Will They fit without modification? I'm at stock AWD height now.
Old 03-03-13, 07:06 AM
  #4330
TimChen
TimChen's Avatar
Front 19x8.5, Rear 19x10 forget the offset, I plan to run 215/35/19, 245/35/19
1. is it gonna be safe?
2. another option 225/35/19, 265/30/19 which one has better look? safety?
Thanks
Old 03-03-13, 03:31 PM
  #4331
Galvez
Galvez's Avatar
SO im thinking of getting some enkei nt03 18x9.5 +27 wrapped on 225/40 and then for the rear 18x10.5 +30 on 255/40. What problems will i be running into for the front and rear? thanks!
Old 03-03-13, 04:52 PM
  #4332
RVCAis250
RVCAis250's Avatar
how low are you going?
and why the 40's? I'd do 235/35 in the front and 255/35 in the rear.
with 235's, you'll need to have your fenders rolled, no pull needed. but you will need to relocate that bumper tab in the front (depending on how low you are, but if you are lower than spring height than you'll need to shave them away)
Old 03-03-13, 05:35 PM
  #4333
projectdna
projectdna's Avatar
235/35-18 in the front, 255/40-18 in the rear = maintain near-OEM rolling diameter.
the fronts will require more work than the rear. front and rear will require at least a fender roll.
Old 03-03-13, 05:55 PM
  #4334
Scless
Scless's Avatar
Anyone?
Old 03-03-13, 08:07 PM
  #4335
Galvez
Galvez's Avatar
Well im going with the 40's since i have them on the stocks. If i gotta get another size i will but i really wanna try to keep that tire size. As far as ride height i would say i have a finger gap all around. So a roll all around? and shave the tabs and I should be good?
Quick Reply: Will those wheels fit? START HERE.
