Will those wheels fit? START HERE.
Old 03-04-08, 06:14 PM
  #241
wilwilB
wilwilB's Avatar
Default will +35 offset fit?
question is on title~ I tried to search for someone with +35 offset on the IS250 but coudn't find any. usually are high 30 on front and mid 40 on rear. I want to know will +35 offset fit on IS250RWD. just want to make sure everything goes right when I purchase the rim tmr! its 19x8.0 +35 semi taper (front), 19x9.0 +35 mid taper (rear).
and I'm looking at Dunlop Direzza DZ101 for tires. 225/35/19 (front) 245/35/19 (rear).
does everything sound good to you all?? will it fits perfectly~~?
Old 03-04-08, 06:16 PM
  #242
HKS350
HKS350's Avatar
They'll fit.
  #243
llamaboiz
llamaboiz's Avatar
yea they'll fit, i run almost the same setup
Old 03-04-08, 06:17 PM
  #244
SPEED&ECO.
SPEED&ECO.'s Avatar
it will fit. you can even go lower and wider
i ran 19x9 and 19x10 +20 all around at one point
Old 03-04-08, 06:35 PM
  #245
wilwilB
wilwilB's Avatar
wow thanks alot guys! really got lots of help on CL ppl reply so fast haha! thxthx!
can I get the Eibach prokit with 19", will there be any rubbing issue if lowered?
Old 03-04-08, 06:46 PM
  #246
llamaboiz
llamaboiz's Avatar
i dont rub but i am on the 350 prokit and not the 250... which i regret not getting instead...
Old 03-04-08, 07:16 PM
  #247
weesped
weesped's Avatar
haha. told u when u first got them u shoulda went 250 .
Old 03-04-08, 09:43 PM
  #248
wilwilB
wilwilB's Avatar
350 doesnt sit as low? why are they different~
Old 03-06-08, 09:18 PM
  #249
shinbrianj
shinbrianj's Avatar
Default Wheel fitment question.
I found a REALLY good deal on AZA wheels Front 18x8 - 235/40/18 Offset:40mm, Rear 18x9 255/35/18 Offset:45mm. Bolt Pattern: 5-120. Will these fit on my IS250? Sorry if this is the wrong section I just needed a quick response. He asking $500 with new Toyo Tr1s. TY
Old 03-06-08, 09:44 PM
  #250
Signal_jp
Signal_jp's Avatar
nope. lexus bolt pattern is 5x114.3
Old 03-06-08, 09:45 PM
  #251
Signal_jp
Signal_jp's Avatar
and the offsets are kinda high for the IS
Old 03-06-08, 09:49 PM
  #252
shinbrianj
shinbrianj's Avatar
ty signal for the quick response
Old 03-06-08, 10:47 PM
  #253
kurdus
kurdus's Avatar
its not impossible. you can easily get custom adapters. which are about 20mm thick so your final et will be lower and much more flush with your fenders. though i dont know specs on the stock wheels. adapters cost about 300ish for all 4.
Old 03-07-08, 02:12 PM
  #254
Retro21IS
Retro21IS's Avatar
Yes it is impossible, the bolt pattern is different.
Old 03-07-08, 02:38 PM
  #255
DaWhole9
DaWhole9's Avatar
No its not...there are adapters to convert 1 bolt patter to another. Its not really a great way to do it and it will add about -20mm to the offset. So they would be 25mm instead of 45mm....which will PROBABLY fit...but a gain, its kinda a rigged way to do it.
Quick Reply: Will those wheels fit? START HERE.
