Will those wheels fit? START HERE.
Old 10-30-10, 08:24 AM
  #1681
MashinA
MashinA's Avatar
Originally Posted by zoli21
hey everyone. I want to purchase a set of work emotion crkais. I m going for an 18 by8.5 in the front and 9.5 in the back. I want to run +25 and +20 offsets. Will there be any rubbing issues of the fenders or quarterpanels on stock height. tires will be stock 225/40 and 255/40
dont beleive so since your not dropping the car
Old 10-30-10, 10:37 AM
  #1682
ApokC
ApokC's Avatar
Hello, I don't know much about tires, but I figured I'd ask instead of just buy something.
Question, I wanna get the 5 Axis X5:F Rims on my stock 06 IS350
I want 19's, but what width and offset should I go with?
Old 10-31-10, 08:05 PM
  #1683
ilv1004s
ilv1004s's Avatar
19 x 9 +15 5 x 114.3 with 225/35/19
19 x 10 +15 5 x 114.3 with 235/35/19
hey guys wat about this set up
will it fit?
Old 11-01-10, 10:13 PM
  #1684
Mv350
Mv350's Avatar
you will be poking and on big bumps you will rub. if you drop and roll all fenders youll be good.
how flush, the sky is the limit.
Originally Posted by LexusGuy35
I have a question about wheels and tire size. I'm not a expert on wheels/tires/offset. I'm considering purchasing these wheel an would like to kno what is the largest profile tire I can put on them without rubbing and will it fill all of the gap without lowering the car?? I also would like the larger profile for ride quality and help prevent wheel damage from pothole strikes. I have a rwd 08 is250. 55mm profile work? Would this look good aswell?
your always gunna have wheel gap. and the bigger the wheel/profile of tire the higher off the ground you get.
will it fit?
mod bumper tab, roll fenders in the front. roll with a slight pull rear.
Old 11-02-10, 02:15 AM
  #1685
carbon350
carbon350's Avatar
Originally Posted by Mv350
you can do a 10.5" but drop first always then wheels
i want to get the 10.5" with the 22 offset but how low would i even be able to go with just grinding the fender no pull? im looking for springs but cant choose which to get.
Old 11-02-10, 05:14 AM
  #1686
NSGxLEX
NSGxLEX's Avatar
Will 19x10.5 offset 15 rear fit om am isx250? Would it be possible to fit without a pull? thanks is advance
Old 11-02-10, 06:56 AM
  #1687
SCWB
SCWB's Avatar
Red face
What kind of "front" fender liner modification do these two front sets require?
Front Set #1: 19X8 +29 with 225/35/19 Hankook V12 EVO and 1.5 inches drop
Front Set #2: 19X8 +37 with 225/40/19 Hankook V12 EVO and 1.5 inches drop
1) Requires No modification at all
2) Heat Gun in some area
3) Dremel/cutting the front bumper tab
4) Both 2 and 3
I am torn between these two.
Set#1 looks better
Set#2 drives better
Thinking all day and night
Thanks for your advise.
Old 11-02-10, 10:12 PM
  #1688
Mv350
Mv350's Avatar
springs would not be low enough for this, not enough camber
235/35 full shave and megan camber kit
4) Both 2 and 3
Set#1 looks better
Set#2 drives better
both are fine but i would go lower offset with 35 series tire over a 40 series on a 19 for an IS
Old 11-02-10, 10:49 PM
  #1689
carbon350
carbon350's Avatar
dang so i guess i wont be going with the tens
well ****** do you think 19x8.5 +32 with 5mm spacer and a 19x9.5 + plus 35 would look good on eibach pro kits?
and would a 15mm rear spacer fit on this setup with only grinding the rear fender?
Old 11-03-10, 02:53 AM
  #1690
tnogi
tnogi's Avatar
Would 10.5 +35 offset fit on the ISX50 fronts?
If so what size tire can I run? and
what kinda fender mod will I need?
Many thnx in advance,
toHn
Old 11-03-10, 05:37 PM
  #1691
350zTT
350zTT's Avatar
Sup everyone, im about to get a is250...looking at some work t1s 19x9 +25 19x10+25 and was wondering if they will be ok with the fenders rolled?
Old 11-03-10, 08:38 PM
  #1692
pheelgood
pheelgood's Avatar
HELP ASAP!!! to all those wheel sizing connoisseur (Mv350) out here im shopping for wheels as we speak...
i drive an 08 ISX50 on AIR
will these fit??
Wheels:
Fronts: 19x9.5 +11
Rears: 19x11 +18
Tires:
235/35/19
275/30/19
i kno the offsets are really low... do i need any fender pulling? or camber kits??
anything will help... thanks!
PM me or ill just check this thread again.. if i can find it
Old 11-04-10, 10:19 PM
  #1693
Mv350
Mv350's Avatar
yes that setup will work. you can go 20mm spacer in the back and youd be fine.
toHn
not sure about a 10.5 up front.
yes, with 215/35 up front, and 235/35 rear, and just roll and drop the car.
will these fit??
Wheels:
Fronts: 19x9.5 +11
Rears: 19x11 +18
Tires:
235/35/19
275/30/19
yes thatll work, but run 225/35/19 up front. pull front and rear. remove bumper tab. and get camber kit for rear, and spc adjustable ball joints for the is300 and use those up front for camber.
Old 11-05-10, 12:19 AM
  #1694
pheelgood
pheelgood's Avatar
thats a lot of work... i dnt even kno where to get to ball joints.. is it gonna crazy camber?
Old 11-05-10, 12:22 AM
  #1695
Mv350
Mv350's Avatar
your air so you can go crazier. they are vendors on this forum that sell spc. and any notable person that can roll and pull with be good enough.
Quick Reply: Will those wheels fit? START HERE.
