Lexus 4GR-FSE Engine Carbon Build-up (merged threads) - Page 2 - Club Lexus Forums
Log In
Thread Tools Search this Thread
Old 02-26-10, 08:45 PM   #16
ahnjae
If you have issues like rough idle and low MPG, then i recommend people to Seafoam there vehicles no matter what car it is. It is completely safe that can be used in the crankcase, fuel tank and intake stream and you immediately see results right away. It will remove almost all carbon build up and will see it all exit out of your exhaust....I have seafoamed all my vehicles after time. This is especially a must if you purchased a used car. Just make sure you do it in a safe place where theres no one around because there is going to be a lot of smoke coming out of your exhaust if your engine and lines are dirty.
http://www.seafoamsales.com/
ahnjae is offline   Reply With Quote
Old 02-26-10, 09:38 PM   #17
IS25Heaven
I have gotten this problem maybe once or twice. Always thought it was my intake not sucking enough air?
But it seems like most people wot 3-6 times a week. I pretty much wot everytime i get on the highway, since 200hp doesnt get you going anywhere. So i wot maybe like 5 times per day.
IS25Heaven is offline   Reply With Quote
Old 03-05-10, 08:51 AM   #18
ajfinoak
My 08 IS 250 with 18K has been at the dealer all week. It finally did it when I pulled in the lot to bring it in so they have seen the intermittent vibration in the steering wheel at idle problem. Regional Service Mgr is there this week also. They thought it might be gas I am using but always use Chevron. Appears from computer it is running a little rich when it happens. Hope they are able to figure it out- third time I have brought it in. Have the HS as a loaner- not impressed- IS even the 250 is much more responsive and handles way better.
ajfinoak is offline   Reply With Quote
Old 03-05-10, 01:20 PM   #19
wolverine
wolverine's Avatar
Quote:
maybe because the HS is not a "sports" car?
wolverine is offline   Reply With Quote
Old 03-05-10, 08:46 PM   #20
DJSirkit13
Wat the hell does WOT stand for.
DJSirkit13 is offline   Reply With Quote
Old 03-05-10, 09:00 PM   #21
T4styPh0
Quote:
Short for wide open throttle
T4styPh0 is offline   Reply With Quote
Old 03-05-10, 09:01 PM   #22
cupid0210
cupid0210's Avatar
^^^^^hahaha, I was wondering the SAME thing!!
cupid0210 is offline   Reply With Quote
Old 03-10-10, 07:34 AM   #23
hades281
thread bump
hades281 is offline   Reply With Quote
Old 04-26-10, 11:41 AM   #24
mjhsnow
Default Rough idle, Check Engine, Carbon Buildup
Since the beginning (2007) i have had the problem of fine running until i exit the freeway, where it runs rough and almost dies at idle. Then fine. It was fixed at dealer with carbon cleaning service, but gets worse again. Just had a severe loss of power, check engine light (accompanied by VSC error). With engine off and back on the problem disappeared. Lexus showed a misfire code on #2 and they found that #2 had a low compression. They propose a carbon service again.
What is the cause of the carbon buildup (i use Shell Premium)?
Any update to software to fix the hot idle problem?
mjhsnow is offline   Reply With Quote
Old 04-27-10, 08:36 AM   #25
hades281
I am hoping that the ECU update for the gas pedal override includes a software improvement for this condition. Lexus is apparently aware of this issue and it would be the perfect opportunity for them to remedy it under the radar. (Or, if the software has been improved for later year model cars, we are probably getting the latest version with that update) Who knows?
Old 04-27-10, 09:31 AM   #26
Evil Teo
Evil Teo's Avatar
when I had my is250 around 25k miles i had the same issue and had lexus cleaned out all the carbon. since then i traded mines in for an F. i dont think wot has anything to do wit it. i wot almost everyday on the is250.
Evil Teo is offline   Reply With Quote
Old 04-27-10, 09:50 AM   #27
DJSirkit13
i used it in my gas tank and a little in the oil worked great but make sure you get a oil change after.
I didn't put it in the PCV line due to the fact we have E throttle didn't want to mess anything up. but just gas tank and oil makes a good diff. NO Smoke though i think you only get smoke if you ut in the PCV line
Old 04-27-10, 10:10 AM   #28
A1Lexis
A1Lexis's Avatar
When I brought my 06 IS with 41K into the dealership for the cold start-up TSIB, the tech told me there was significant carbon build up on the TB and he cleaned it using 3M TB cleaner and gave me an extra can. He said running high octane or WOT won't hurt, but it will not prevent it. He strongly suggested adding fuel injection cleaner at every other fill-up and cleaning the TB every 15K miles. After he cleaned the carbon, I immediately noticed my car didn't have the hesitation or feeling like it was going to die at a traffic light anymore.
A1Lexis is offline   Reply With Quote
Old 04-27-10, 02:21 PM   #29
LyleBeach
I have a friend with an 06 GS300 with the same problems. He has around 30,000 miles on the clock. Took it to Lexus, they had the car for several weeks, pulled the head, found large deposits of carbon build up.
Seems this problem is not just with the IS.
LyleBeach is offline   Reply With Quote
Old 04-27-10, 06:55 PM   #30
shui3000
does anybody know if you can just put seafoam into the brake booster tube like all other cars, or is our car just so damn special
shui3000 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
6 new fuel injectors and $1400 worth of warranty work bam Hybrid Technology 9 06-13-16 09:53 AM
Carbon Build-up Issues in Canada - Any Success w/ Lexus? meis250 Canada 47 04-11-16 04:04 AM
Buyer's Guide to Used Lexus 2nd Gen IS Models (merged buying advise threads) DaveGS4 IS - 2nd Gen (2006-2013) 360 02-14-16 11:21 PM
***** New TSIB to treat Carbon Build-up **** TWong350 GS - 3rd Gen (2006-2011) 38 04-28-15 02:13 PM
Rough idle, from using accessories??? Fizzboy7 IS - 2nd Gen (2006-2013) 6 08-23-14 08:49 AM
Tags
250, 4grfse, build, buildup, car, carbon, cleaner, diagnostic, direct, engine, fee, idle, idling, injection, is250, issues, lexus, lsb002910, normal, problem, problems, questionroughidling08is250is250roughidle, rough, springs, tsb, tsib, uneven
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
