FlyAudio Install Instructions (56K BEWARE)
Got a couple of questions:
1. If I feed the mic wire to the upper console like OEM, can the wire be tucked all the way up the A-pillar and under the headliner? Or does the headliner need to be removed?
2. How do I remove the upper console?
3. How do I remove the rear seats?
Thanks.
Thanks.
Evan, I sent you the signal wire just to make sure. FlyAudio says that the signal wire is only necessary on the Lexus model, but I am skeptical. You may need it, you may not.
The FlyAudio plugs and plays. There is nothing to drill. For the GPS antenna, it depends on where you want to mount it. Some mount it on the dashboard and you don't really have to remove anything. If you want to mount it in the rear window behind the passenger headrests, you have to remove side paneling, rear seat, seat belts, etc. It all depends on where you want to run the wiring.
Thanks.
Thanks.
Curios on the answer to Mark first question?
Wil is right, you don't need to remove the headliner. Luckily on the IS 250/350/F, you don't need to remove much. We installed a FlyAudio on a VW GTi a couple of days ago and the headliner was sealed off and there was no tucking it under.
