changing spark plugs
Old 02-03-10, 06:08 AM
  #31
Koz
Koz's Avatar
NGKs will be available in the spring, I'll wait.
Koz
Old 02-16-10, 07:18 PM
  #32
Blackswan
Blackswan's Avatar
OMG. I was just browsing and found this thread luckily. I just came back from the dealers here in Mississauga, Ontario for oil change and they were recommending to change my spark plugs as well. They were charging me a whoooopping $370 bucks to change it and they said it takes 2 hours to do it and it includes 6 plugs for the IS250. I'm no expert but I knew something was wrong with this $$$ figure. I said I will get back to them on that one. From what I've read here, plugs are in the range of the $ I was thinking. Hahahahaha. These dealers just make me laugh! This thread saved me money.
Old 02-16-10, 09:06 PM
  #33
shui3000
shui3000's Avatar
they were charging you for the labor... of course the parts are cheap.
go to your car and try to find the spark plugs, i dare you.
Old 02-16-10, 09:55 PM
  #34
edgeucated
edgeucated's Avatar
is their any DIY yet? i have yet to look for my sparkplugs, but are they hard to get to? I help my friends change their sparkplugs on BMW all the time, but i have to admit BMW engines are much better laid out
Old 03-02-10, 01:04 PM
  #35
Corbio
Corbio's Avatar
How about the denso spark plugs, does anyone have recommendations on where to purchase the FK20HBR11 online?
Thanks!
Old 03-02-10, 01:22 PM
  #36
blk250
blk250's Avatar
Hi, There was no thread for it, but if you follow this thread
https://www.clublexus.com/forums/is-...ine-cover.html
to reach the driver-side spark plugs.
good luck
Old 03-02-10, 01:25 PM
  #37
edgeucated
edgeucated's Avatar
thanks for the link blk250, imma save the link. it shows decent pictures but imma still hope by the time i have to change my sparkplug there will be a real diy
Old 03-03-10, 11:00 AM
  #38
teracon
teracon's Avatar
Default Found them for less - $10.95 + free shipping
I located them here - http://www.drivewire.com/search/?D=s...:Base,engine:6 Cyl 2.5L,universal:0)&refValue=qualifiers&events=Type-Direct OE Replacement
Old 03-04-10, 09:15 AM
  #39
Corbio
Corbio's Avatar
Hey Teracon, thanks for sharing the link and a good price too I must say
Old 03-05-10, 10:10 AM
  #40
teracon
teracon's Avatar
No problem. I ordered them yesterday and they arrived a few moments ago via UPS. So far, a good vendor..
Old 03-05-10, 06:09 PM
  #41
Duke02
Duke02's Avatar
Originally Posted by B16da9
I've never done it on an IS but its probably just like any other car.
1. Take of engine cover.
2. Disconect the coil to the specific cylinder you are working on (do one at a time).
3. Remove what ever holds the coil down to the valve cover.
4. Remove and install new spark plug.
There's you DYI.
I think on the IS, you have to remove the intake manifold to get to some of the plugs.
Old 03-08-10, 11:22 AM
  #42
Corbio
Corbio's Avatar
Considering that the manual states that the Denso FK20HBR11 should be used, how does the Denso SK16R-P11 in the link perform to the previously-mentioned one? Is it compatible in any way because I checked the denso website and it does not list the SK16R with the IS250.
Old 03-17-10, 09:46 PM
  #43
teracon
teracon's Avatar
I had to return the NGK plugs from drivewire.com. I pulled the old plugs out and noticed that the new NGK plug was nearly an inch shorter and had only a single side electrode. The factory plug has three side electrodes.
Luckily I only started on the passenger side first. Just received my plugs from Carson and plan to install them this weekend.
Old 03-17-10, 10:49 PM
  #44
uz07lex
uz07lex's Avatar
I think the dealer wanted $300 to change the plugs so I just Did it myself. Some basic tools and It must of took an hour total. You have to take off the sheilding and intake to get to the plugs. The torque I think is 25n/m ill check it out. I went with the stock plugs for $110 but it was 8 plugs that I bought. 2 extra just in case. The car did run alot smoother.
Old 03-23-10, 01:35 PM
  #45
Corbio
Corbio's Avatar
I ordered the 6 densos through a friend of mine at toyota and they cost at $100 with the employee discount. Wasn't sure if the 3 double o-rings at the intake manifold are required to be replaced as well.
So here go my questions:
Is 25n/m the correct torque for the plugs?
Do the o-rings have to be replaced when changing the spark plugs?
Thanks beforehand
cheez
SC- 1st Gen (1992-2000)
04-20-10 05:43 AM
southtrian
Maintenance
04-13-06 11:05 AM
indypwr
GS - 1st Gen (1993-1997)
12-17-02 08:19 PM
Quick Reply: changing spark plugs
