DIY - Fix cracking noises from center dual vent
Whats the color code or name of the paint?? TIA
I know I'm reviving a really old thread. I've been getting that annoying cracking sound from the driver's side air vent. I've taken it to the dealer and they removed the vent and placed the felt behind it, but I it didn't fix the problem. I'm trying to figure out how to remove the driver's side air vent but cant get it off. I can't see any tabs for it either like the two central air vents have. I would like to take it off and see if I can see where it's rubbing and possibly place some graphite spray behind the vent. Any advice on getting the driver's side air vent off?
EDIT: Just noticed that this comes in a tube too. Might try that..
Mega necro bump. Curious if anyone else has done this fix? I also have not a RATTLE like some but this creaking which can only be described like pushing/plastic.. I can recreate it by pushing on various areas on the vents, nav unit, etc.
This crackle and some sort of small buzz at passenger door are the two last sounds i need to eliminate from my 350.
anyone else done this crackle fix with success??
Necrom bump #2. Nobody else?
I actually cannot get my center AC vent out. I am supposed to pull the 4 tabs DOWN but they appear to be like wedged up in there and I cannot get them down. i tried to pry the unit out very carefully and all im able to do is just loosen the trim around the housing and not the ac unit itself.
im pretty sure if i can get that thing out of there and really insulate/felt/rubber all of the various pieces I could make this darn creaking go away
PLEASE tell us what brand and color number of the paint you used.
I thought I was the only one.. It **** me to tears hearing it creaking and cracking.
I took my car for the airbag recall 2 weeks ago, not sure what they did, the sound is gone!
Got my airbag fixed and the noise gone.
umarali
LX - 3rd Gen (2008-2021)
10-07-15 10:10 AM
