Prodrive GC-014i / Volk Progressiv ME
Old 01-23-10, 11:03 PM
  #61
edwa
edwa's Avatar
Question is250 AWD?
Will these fit the my wife's 06 is250 AWD? I'm getting the Fsport springs in the spring, should I buy set, plus what offset should I get? Don't want any issues with any sort of rubbing causer its her daily driver. Also , is it TPMS compatible?
thanks,
ed
Old 01-23-10, 11:33 PM
  #62
DasNutz
DasNutz's Avatar
I like-em
Old 01-24-10, 01:42 AM
  #63
VikH
VikH's Avatar
thanks,
ed
My MEs are TPMS compatible, so they should be as well.
Old 01-25-10, 12:47 AM
  #64
edwa
edwa's Avatar
Thanks Vik,
What about the offset? I'm a complete noob with wheels and tires.
Seems like the +22 offsets might be too much for me. If I get the 19"x8.5" +45 would that be okay?( consevative)
thanks in advance,
ed
Old 01-27-10, 12:58 AM
  #65
edwa
edwa's Avatar
Question offsets??
Any of the wheels guys have an answer??
Old 01-27-10, 04:35 AM
  #66
t0e
t0e's Avatar
19"x8.5" +45 is very conservative, almost like stock.
You should be ok...
22 is fine if you dont plan on lowering.
Also, I wouldn't consider the "F" sport springs much of a drop...
Old 03-09-10, 03:43 PM
  #67
redline201
redline201's Avatar
any idea what size hub bore these things are? looking to mount mine up asap. everything is in Japanese.
edit. they have a 73mm hub bore.
Old 01-04-13, 08:59 PM
  #68
br3akenout
br3akenout's Avatar
Reviving this thread because ill need help once I get mine in. Bought them off a fellow member on the forums but will be running it on an AWD as opposed to his rwd. I plan on lowering on bc racing coilovers so I need some help on tire sizes as well as if I would need spacers. I also want to know if my fenders will need to be rolled. I plan on dropping 1.5 to 2in all around. Still deciding to be honest.
Here are the specs:
19 x 8.5 +22
19 x 9.5 +25
These are the recommendations I've gotten so far. Of the 3 which would be best for the awd? Are there any other options? Do i need to run spacers? I just wanted to put all this info down for anyone else that may run into this instead of scouring the forums like I've been. Thanks to 07awdis250 for the options listed below:
225/35/19F and 235/35/19R (current setup for 07awdis250) - looks like rear tires will be stretched?
235/35/19F and 255/30/19R
225/35/19F and 265/30/19R
Since I'm dropping on coils with this setup am I going to need a camber kit for the front and/or rear?
I apologize for all the questions. It's my first set of wheels and I want to make sure I get everything right. Thanks!
buckxwild
Wheels and Tires Classifieds
07-08-12 12:50 PM
kraze8
03-14-07 10:27 AM
Quick Reply: Prodrive GC-014i / Volk Progressiv ME
