Old 12-16-14, 11:40 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
Print Wikipost
DOme light cover removal need help
Old 02-06-11, 07:13 PM
  #31
MSirJet
MSirJet's Avatar
Dome light bulb change.... I was going for the two screw whole assy removal method But the aft end didn't want to pull out... So I used a six inch rule (a very flat thin six inch ruler) and popped down the fwd edges, no dents or scuffs.
Old 08-27-11, 06:32 PM
  #32
TETO
TETO's Avatar
HOW to remove the one on the back ???
i can't remove it ..
Old 08-27-11, 08:53 PM
  #33
wyee99
wyee99's Avatar
^it's easy.. you just take a flat head and pop it out.
Old 09-02-11, 01:43 PM
  #34
TETO
TETO's Avatar
thanks pal ...
Old 09-02-11, 02:56 PM
  #35
dojoman
dojoman's Avatar
Flat head won't work without scratching up the plastic and it will look like crap in the end. My method works the best and no screw driver needed. Go to walmart and buy a suction cup with hooks where you can hang small items on the mirror. Use that to pull the dome cover. Just one strong yank it will come off.
Old 09-02-11, 08:30 PM
  #36
TETO
TETO's Avatar
done .
Old 09-03-11, 04:29 AM
  #37
Joeb427
Joeb427's Avatar
Originally Posted by Initial_K
First get a small thin knife like this. If you have a very thin flathead that will work too, but all my flathead were too big. You will need this something thin and strong enough to detach the clips from the socket.
There are four clips holding the dome cover together. Unclip the two that I highlighted using the edge of the knife. Shouldn't take too much force to unclip it from the socket. Once you detach the two clip, it should come down easily.
Next, don't twist on the light bulb. Simply pull straight down.
Hope this helps.
Anybody try this on a '10 or '11 with the two lens covers because of the Enform button?
Old 03-05-14, 07:33 PM
  #38
Mike4puy
Mike4puy's Avatar
How about the HS250 dome light removal.
Old 11-27-15, 11:47 AM
  #39
Sheldon06
Sheldon06's Avatar
Default I can't remove these lights
Originally Posted by DJSirkit13
I just ordered 5 led boards from nigel jdm parts. but having a few issues with this.
1.) I can't get the front cover of (yes i did remove the two screw)
i searched but couldn't find any DIY with pics and I knw for a fact alot of ppl have changed the bulbs so please help, ive read to pull the front down hard as possible but which front the one by the windshield or the side facing the rear?
2.) Has anybody ordered the LED boards from nigel and are they really as bright as some people say they are?
3.) if they are really that bright do I need two in the rear dome or is one enough? ( PS I plan on putting two in the rear and 3 in the Front but if i only need one in the back then i can use the xtra for the trunk)
4.) Where in the front & rear dome light housing did you stick the board two I wouldn't think it would be safe to stick some thing to the connectors that hang dwn but if there is no danger y not.
5.) can those led boards be used for the door courtsey and the mirrors again where and how would i stick them too.
Thankyou & please help really need help with these problems want to get it all done within the next couple of days
Dome and Map lights. Only one light works and i'm trying to trouble shoot the problem. Heeeeelp. 2006 GS300.<br/>
largo25
ES - 5th Gen (2007-2012)
02-05-17 11:20 AM
Rosson3ri
05-02-16 08:58 PM
sc400
RX - 3rd Gen (2010-2015)
01-16-15 08:05 AM
CashOverAs
01-16-09 06:46 AM
triplecore
12-04-08 04:25 AM
Quick Reply: DOme light cover removal need help
