When Was Your First Oil Change (IS X50)?
Old 07-21-09, 02:08 PM
youngim87
youngim87's Avatar
Question When Was Your First Oil Change (IS X50)?
Hey guys,
I have a 09' Lexus IS 250 and have just reached the 3,000 mile point. I owned a honda accord before and changed my oil every 3,000 miles and was used to this so I decided to take my IS to a mechanic to change my oil and save the 5K free service oil change for around 5.5k miles. I was told I shouldn't change it because it only needs it changed every 5k, so I didnt.
I was wondering when everyone got their first oil change for their IS's? Is it good to get the oil changed earlier than 5k, like around 4.5k, because I have read somewhere on here that when the engine first breaks in that it releases more metals and crud into the oil than normal so it is best to change it earlier. Whats your input on this?
-Thanks
Old 07-21-09, 02:25 PM
Kurtz
Kurtz's Avatar
Originally Posted by youngim87
Hey guys,
-Thanks
3k oil changes were great in the 1950s when that rule was first put out...
with modern manufacturing it's literally pouring money down a drain.
Using normal oil you can safely go at LEAST 5k (most used oil analysis suggests 7500-10k is safe on regular oil in a 2IS honestly).
With a good synthetic you can comfortable change the oil once a year so long as you don't go past 20-30k miles in that year.
Old 07-21-09, 04:09 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
change it every 5K
Old 07-21-09, 05:07 PM
mvlbr
mvlbr's Avatar
I changed it for the first time around 4200 miles when the message showed up on the dash.
Old 07-21-09, 05:09 PM
Maxximus
Maxximus's Avatar
I did mine at 4k but it was also 8 months after I bought the car, wanted to get it cleaned out.
Old 07-21-09, 06:59 PM
hmsis250
hmsis250's Avatar
I did mine a couple hundred miles before 5k!
Old 07-21-09, 08:22 PM
IAMJAVEDG
IAMJAVEDG's Avatar
first one was done at 3k so that was 37,000 miles ago
Old 07-21-09, 08:50 PM
yukikaze
yukikaze's Avatar
I did my first at around 3.8k, around 9 months after I got the car.
Also with synthetic oil used, is it safe to keep using the oil filter for more than 5k miles?
Old 07-21-09, 10:14 PM
Fizzboy7
Fizzboy7's Avatar
Always follow what the factory recommends. They are the ones who test these cars under extreme conditions for years before they are released to the public. They know best. 5k miles or you are wasting your money. The 3k rule is old-fashioned and outdated with today's modern engines.
Old 07-22-09, 05:58 AM
Kurtz
Kurtz's Avatar
For old fashioned dino oil 5k is fine. Actual used oil analysis on actually 2ISes has suggested 7500 would be just fine too.
For a good synthetic like Amsoil you're wasting your money changing it more often than 25k miles or once a year. UOAs on 2ISes have suggested that even lesser sorta-syns like Mobil 1 are good for at least 12-15k miles.
Old 07-22-09, 06:08 AM
Koz
Koz's Avatar
UOAs have shown that you can safely run the OEM oil filter for one year, even with dino oil. There is no need to change it every 6 months. Years ago (Many) you could change your oil filter every OTHER oil change.
Koz
Old 07-22-09, 06:21 AM
jc86
jc86's Avatar
first one at 5k =)
every subsequent one i go around 6.5.
Old 07-22-09, 06:23 AM
IntegresS
IntegresS's Avatar
I changed mine at about 1,000 miles but only because it was already about 6 months after I got the car.
Old 07-22-09, 09:16 AM
BoOst3d
BoOst3d's Avatar
my first oil change was at 5k but you can change it sooner because it is a new engine so there are some machining shaving in the motor you might want to get out. other than that, i do 10k mile oil changes.
Old 07-23-09, 11:18 AM
Audiofan2
Audiofan2's Avatar
I also subscribe to this theory and thought for the $30 it costs, why not? I wanted to switch to Mobile 1 anyway because I planned on owning the car for a long time, so I did the first change at 1k miles.
Quick Reply: When Was Your First Oil Change (IS X50)?
