F-Sport Rims, fit AWD?
Old 04-29-09, 09:00 AM
RHui_BC
RHui_BC's Avatar
Default F-Sport Rims, fit AWD?
So, in my search for f-sport rims, I found 5 part numbers.
19" Front part# PTR45-53081 (19x8, +40mm) (20lbs)
19" Rear part# PTR45-53082 (19x9, +40mm) (21lbs)
Install kit for 19" PTR27-53080
and then these:
18" IS250 AWD PTR45-53083 (18x8, +?mm) (22lbs)
Install Kit PTR27-53090
1) Anyone know if the 19" set will fit the is250 AWD as long as i keep the tire diameter the same?
2) What is included in the install kits, is it just lug nuts/lock nuts?
3) Do I need the install kits? Or can I reuse lugnuts from stock 17" OE rims.
Old 04-29-09, 11:06 AM
OutCaster
OutCaster's Avatar
They make 18in. version of f-sport wheels for AWD.
Old 04-29-09, 01:12 PM
RHui_BC
RHui_BC's Avatar
Yup, or i can just order 2 sets of the 19x8s.
Old 04-29-09, 02:15 PM
acefalcon2
acefalcon2's Avatar
hmm you should be okay just remember to keep your running diameter close to one another
Old 04-29-09, 09:16 PM
cre8
cre8's Avatar
Yes, It will fit 19 or 18.. No Problem.You can even go with stagger setup.Tire size you should go with 225/35/19 front and 265/30/19 rear. ( On my car, lower with Tein S Sport )NO AWD WARNING LIGHT!!!
Lug Nuts and Lock, you will have to go with F Sport lug nuts or something else. No way that you can put stock lug nuts on F Sport. It wont fit. Good Luck...
Old 04-30-09, 12:15 AM
love67
love67's Avatar
235/35/19 and 275/30/19 is the closest you can get for AWD. even 225/35/19 and 255/35/19 will work too if you want to, this set up will not have warning light.
Sybaritic
04-23-17 01:27 PM
Shinedown
10-29-15 07:04 AM
thebd
06-16-15 08:54 PM
DjVolume
07-20-09 08:36 PM
Quick Reply: F-Sport Rims, fit AWD?
