About to pull trigger on Rims and Suspension. See anything wrong with my selection?
Old 03-22-09, 08:34 PM
Coconut
Coconut's Avatar
Default About to pull trigger on Rims and Suspension. See anything wrong with my selection?
I'm about to pull the trigger on new rims and springs. Do you see anything wrong from my proposed setup?
RIMS:
Work Emotion CR Kai in Gunmetal
-Front: 18x8.5 +38mm
-Rear: 18x9.5 +38mm
-Bolt: 5x114.3
LUGNUTS:
Ray Shorty Lugnuts in Gunmetal
-conical/acorn type
-M12 x 1.5mm
HUBCENTRIC RINGS:
-plastic
-will be getting them at local tire outlet chain
TIRES:
Reusing stock front 225/40/ZR18
Reusing stock rear 255/40/ZR18
VALVESTEM:
reusing stock TPMS
SPRINGS:
F-Sport Springs
-reusing stock shocks
-mild 1-1.2" drop all around
BBK (sometime around SEPT)
F-Sport Front BBK
F-Sport Rear BBK
Old 03-22-09, 08:41 PM
istundra
istundra's Avatar
I've seen and do agree that f-sport lowering springs do not give that much of a drop.
I've also seen Prokit for IS250 gives a good drop....
Nice choice on wheels.. doing anything about not having a center cap?
Old 03-22-09, 09:02 PM
DoTheDrew
DoTheDrew's Avatar
id say get eibach's for the 250, h&r's, or teins. people always regret not dropping it a little more unless you're content with a mild drop.
Old 03-22-09, 09:14 PM
acefalcon2
acefalcon2's Avatar
go S-Techs or something else... the Volks needs no Hubcentric rings if they are already custom made from japan... make sure u do get something that clears BBK.... other than that..it looks good...it's better to buy your BBK first since they are on sale though
Old 03-22-09, 09:19 PM
istundra
istundra's Avatar
yeah.. at +38MM.. not sure if that will clear BBK..
Old 03-22-09, 09:22 PM
2slow
2slow's Avatar
I say go with H&r springs. It'll make your rims look hot.
Old 03-22-09, 09:27 PM
ExTrEmE99
ExTrEmE99's Avatar
Get 19" wheels! If your going aftermarket, might as well bring the size up a little! Plus it will fill in the wheel gap a little.
edit: didnt see you were going to use your existing tires.
Old 03-22-09, 09:33 PM
A1Lexis
A1Lexis's Avatar
I think it will look awesome! Wish I had that setup on my car. Best of luck!
Old 03-22-09, 09:39 PM
Ikonz350
Ikonz350's Avatar
say no 2 F sports... and No 2 18's :P
Old 03-22-09, 09:44 PM
tfz_hebe89
tfz_hebe89's Avatar
I say go with coilovers.. and 19" wheels..
Old 03-22-09, 09:48 PM
javyLSU
2IS OG
javyLSU's Avatar
HUBCENTRIC RINGS:
-aluminum preferred over plastic
Any particular reason you prefer aluminum over plastic? I can't stand the aluminum ones - they're difficult to get off, and warp/bend easily when you do get them off. My recommendation is to get the plastic ones.
SPRINGS:
F-Sport Springs
I'd go with H&R's over the F-Sport springs. Better drop for pretty much the same price (if not cheaper).
That's not true. Volks come in a 72mm center bore, requiring a 72-60.1mm hub ring for use on any Lexus/Toyota vehicle.
+38 will be fine to clear the F-Sport BBK.
Javier
Old 03-22-09, 10:25 PM
Mr.JPG's Avatar
I am in the similar situation as coconut but i want to go for +30 for the rear wheel. I have a 250 with Tein CS coilover drop. Am I going to have any rubbing issue if i'm using the stock 255/40 rear tire?
Old 03-22-09, 10:38 PM
llamaboiz
llamaboiz's Avatar
ppl talking about clearing a bbk, it has nothing to do with the offset, it has to do with the disk (face of the rims), if you plan on putting on a BBK or even a 350 brake swap you'll need a R disk or High disk, different brands use different names. Buy the rims correctly then you wont have to run spacers
Old 03-22-09, 10:44 PM
Anthony
Anthony's Avatar
IMO you will probably want to go lower later to eliminate the wheel gap you will probably still have after F-sport or Eibach springs..
Also
Which work wheels you planning on getting?
19's!
Old 03-22-09, 10:55 PM
wolverine
wolverine's Avatar
i agree with this.
Quick Reply: About to pull trigger on Rims and Suspension. See anything wrong with my selection?
