Optional rear tire size on the 18" IS Wheels
Hi all,
Sorry if this has been posted elsewhere. I've searched and haven't been able to find. We all know how limited we are in terms of selection when it comes to the OEM 18" matched set tires. Dropping the rear from a 255/40/18 to a 245/40/18 more than doubles the selection.
I've checked on 1010tires using their tire size calculator and the switch seems to be ok even though I'd be giving up a little width.
I'm just wondering if anyone else has tried this or can verify that I'm not likely to screw something up if I should do so.
As always, thanks, your insight is appreciated!
I just received an email response from Tire Rack. They say the car's electronics and suspension are set up for 255/40/18 and they recommend against chaning the size as it would be "short in diameter."
Can anyone confirm if there would issues? We're looking at a difference in diameter of less than 1/3 an inch.
Depends on the spacer you get. H&R spacers require that you swap out the wheel studs completely with the new ones that come with the spacers. There are a couple of brands (Ichiba and Kics I think) that have built-in studs, so install is a little easier.
If you go smaller...
