Can the NAVI run with no disc?
Old 01-21-09, 11:21 AM
smoking1
smoking1's Avatar
Default Can the NAVI run with no disc?
I just got a loner fom the dealer and i hit the eject button on the navi and it said no disc. Can these cars run with no disc or did the dealer just lock the disc in the drive?
smoking1 is offline
Old 01-21-09, 12:09 PM
Phil888
Phil888's Avatar
hmm I think you always need the disc. You should tell the dealership rite away or else they might think you stole the disc when you return the loaner!! Better to be safe then sorry!!
Phil888 is offline
Old 01-21-09, 12:34 PM
smoking1
smoking1's Avatar
Default the wierd thing is that the nav works just fine...
the wierd thing is that the nav works just fine...i wonder if the 09 has a HD that can store the map data on? Strange....
I bet they lock the drive somehow?
It is an es...where is the dvd drive on those for 09? I think it comes out of the dash 6 disk, right?
smoking1 is offline
Old 01-21-09, 01:16 PM
Dirtywater
Dirtywater's Avatar
Dealer told me that some models (not the IS) have a hard drive based Nav for 2009. Then again, who the F knows if anything a dealer says is correct, lol.
Dirtywater is offline
Old 01-21-09, 01:31 PM
ExTrEmE99
ExTrEmE99's Avatar
The navigation dvd isnt stored in the CD player its stored behind the clock area.
ExTrEmE99 is offline
Old 01-21-09, 01:36 PM
smoking1
smoking1's Avatar
so how would you get it out, take apart the dash? That seems like a bad place for it...
smoking1 is offline
Old 01-21-09, 01:41 PM
ExTrEmE99
ExTrEmE99's Avatar
There are two holes on the side of the clock area, all you do is push a paper clip or something and it pops out.
I think Please correct me if im wrong.
Old 01-21-09, 01:42 PM
smoking1
smoking1's Avatar
cool, ill check that out....thanks
smoking1 is offline
Old 01-21-09, 02:05 PM
Ta250
Ta250's Avatar
Why are you trying to the disc out of a loaner? Just curious..
Ta250 is offline
Old 01-21-09, 02:18 PM
smoking1
smoking1's Avatar
i was going to see if i liked the 8.1 map or if i should just stick with 7.1
smoking1 is offline
Old 01-21-09, 02:20 PM
smoking1
smoking1's Avatar
OK, it sounds like there is something behind the clock but there are no pinholes on the 09 ES. It looks like i would have to take the whole freaking dash apart to get it out. WTF!
smoking1 is offline
Old 01-21-09, 02:25 PM
ExTrEmE99
ExTrEmE99's Avatar
Dont jack the dealer Getting a loaner is a privilege and dont ruin it by "testing" out the new navi disk. It will most likely look the same on the ES as it would on your IS.
Old 01-21-09, 02:35 PM
smoking1
smoking1's Avatar
what the heck are you talking about. I wasnt going to jack the dealer. The reason i asked if it can run without a disc is because when i hit eject no disc came out and if the 09 es has a hd then we may be able to do that on an is. And for the map data...there is a **** load of construction going on in my city. I dont want to pay for a disc upgrade if it dosent have any of it....i was not going to jack the dealer... they would obviously figure out that i took out the disc even it it could run without it.
so back to the topic....how do i get the disc out of an 09es? there are no pin holes and it seems odd that they would put it somewhere that would be extremely hard to get to....or does it....greedy bastards!
smoking1 is offline
Old 01-21-09, 02:42 PM
ExTrEmE99
ExTrEmE99's Avatar
Then this thread needs to be moved to the ES forum. I thought originally you got a IS, some of the cars have the navigation dvd in the glove department.
Old 01-21-09, 02:50 PM
projectdna
projectdna's Avatar
(bolded for emphasis)
first of all, wrong section. you should ask the ES guys.
second, why you messing w/ a loaner? the dealership is nice enough to give you a loaner while your car is in service; don't screw it up by messing w/ the loaner. you just might be the reason they change the loaner policy.
third, the eject button is for the in-dash CD changer, not for the DVD nav.
this thread is getting shadier by the post...
projectdna is offline
Quick Reply: Can the NAVI run with no disc?
