Oil Change Light
I just cut and pasted from this thread for you...., You can do a search next time
https://www.clublexus.com/forums/is-...eqd-light.html
basically all u have to do is this to reset it is....
To reset the data, perform the following operations:
1. Push the “ODO/TRIP” button to change the display to
blank.
2. Turn the ignition switch off.
3. Turn the ignition switch to “ON” with the trip meter
“RESET” button held down.
4. Keep pushing the “RESET” button for longer than 5
seconds after the ignition is turned on.
After the above operation, the master warning light comes
on, a warning tone sounds and the above message
appears to inform you that the engine oil maintenance
data has been reset. (U.S.A. only
blank.
Joseph22T
IS - 1st Gen (2001-2005)
01-12-13 03:05 PM
abbeyrd
12-18-10 03:06 AM
