Is everyone's GFX kit taped on with double sided tape?
Took a look at a Tungsten Pearl IS350 with the GFX kit (front lip and rear lip) and noticed that it was taped on. The guy taped it on himself and I was looking at the edges where they met on the kit and car, and there's a little gap big enough to see some of the tape. I wish I had a good camera, but from afar you can't see any gaps. Up close you can see them, I'm just concerned rain water might loosen the tape and the kit would fall off.
Should the GFX front and rear lip be SNUG against the car panel? Or should there be some small gaps because of the tape thickness?
Did the tape lift from either contact point?
For mine, front - tape and OE bolts only. rear - OEM spec install (drill & cut),
Regarding the gap, please reference to the install manual. Check sewell, they have PDF manuals available for viewing.
I had mine since summer of 07, holding up well.
Ummm. Not really. Those tabs on both ends are stuck on with double sided tape, but the rest of them are not. I removed these tabs from the OEM front lip as it already has six or seven screws holding it on, so that one's not going anywhere. As far as the back goes, I did drill and cut the rear bumper. I have ZERO gap. The exhaust openings on the bumper and GFX kit are different, which is probably why you saw a gap on the car with just the double sided tape install.
The kit...if installed correctly(front and rear) is not held on solely by double sided tape. My rear piece has been installed by drilling a few holes along with the double sided tape to help reinforce it. Now when Lexus initially installed the kit there was a noticeable gap ...i simply took it back and had them reset it. It's near perfect now. It's all in the install.
i just took a look at the installation instructions from sewell and it looks like you had to drill some holes into the actual bumper so basically once you put the GFX front and rear lips on, there will be hole when you take them off
inwood, did you buy your IS with the GFX alrady installed?
yea mine have the holes drilled for the rear and the front is just taped on and bolted from the bottom.
Lexus made it pretty idiot proof if you want to drill the holes since the spots are all premarked on the bumper cover.
