GFX Rear Installation Tip(s)
According to the instructions you would need to disconnect the neg. terminal of the battery, and when taking off the bumper, disconnect a connector for the sensors. Thats about the only difference I see.
the hole's will definitely be noticeable if you remove the GFX kit after installing it. Not only do you drill holes, but cut out around the exhaust part of the original bumper. I think lyndred's old thread had shown what the bumper looks like after cutting it.
No problem...found the thread check it out...post #2...eek...
https://www.clublexus.com/forums/sho...ground+effects
I'm dreading cutting into my bumper, but it will all be covered by the GFX kit, so its all good.
