Change your gear oil every 15K
Lexus calls 30k service intervals on their rear end gear oil service intervals. I call BS on that. Its just another way for most manufacturers are stretching their maintanance intervals.
Granted, I've done a couple of HPDE events and drive fairly spiritedly on the street. I was concerned about the gear oil's condition. I decided to change it. I purchased 2 qts. of Cartrol Syntec 75W90 gear oil and replaced it today. Of course I won't "feel" any difference in it. But I knew it needed it. The magnet was full of crap as expected since the gears are meshing (breaking in) and the oil is being rapidly worn out as the particles are becoming suspended in it. The oil was thin to where it felt less than a 50W. I'd say the first service interval shouldn't be any more than 15K. I know a lot of the guys on this board are concerned about the maintanance and longevity of their vehicles and this could be valuable info for those who would like to keep their wear levels reduced as much as possible.
-Joe
-Joe
With most manufacturers suggesting higher intervals for service. It is usally the purpose of being more eco friendly. I know, I know, yea right... but the use of synthetic oils allows more infrequent services than an underlying sabotage by Lexus. Rear axle oil has no combustion contamination to degrade the fluid in the rear end. Thus allows more infrequent services. If the vehicle rear end undergoes towing (excessive heat,breakdown in antifoaming agents) or submerge under water (ie: trailers backing into water) then water can get in to vent system. Then the MFG suggest a more frequent exchange. Bottom line is..... to each their own! We all feel more confortable servicing the fluids much sooner than the MFG suggest..as with most manuels...it is only a guideline not a standard.
We cant be talking about Tranny oil? are we?
I'v heard you should just leave it alone, till it breaks, and call it a day.
Otherwise, by replacing the oil, you can actually cause damage earlier, to the transmission.
This is just what a mechanic told me, that really takes car of his cars....
He said, just wait till it break and buy a new one?
Im still not sure about it.
There's also no place to hook up a conventional fluid exchange machine because there's no cooling lines carrying transmission fluid.
This thread discusses at considerable length why it's physically impossible to change the transmission fluid.
https://www.clublexus.com/forums/sho...d.php?t=236728
It's mostly on pages 3-5 that it shows the technical diagrams, including how much fluid you can get out doing various services... none of them (including replacing the torque converter) can get more than 1/8th-1/2 of the fluid out.
