18x8.5 w/ 35mm offset for the front, any problems?
Old 05-22-08, 10:00 AM
rfx45
rfx45's Avatar
Default 18x8.5 w/ 35mm offset for the front, any problems?
Alright guys, I have decided to get a drop and just replace my 18's with new wheels.
I decided to order from TireRack.com but I called them up and they said the 18x8.5 w/ 35mm offset was good for the rear only. I want to get 18x9.5 w/ 38mm offset for the back and put the 18x8.5 in the front. Would it cause any problem? Rubbing?
Any help is appreciated. Thanks.
Old 05-22-08, 10:50 AM
isam250
isam250's Avatar
yes there will be rubbing. im running 18x8.5 and 18x9.5 +32 all around i rub on hard turns n fat people in the back cause of my drop and i didnt roll my fender
Old 05-22-08, 11:08 AM
rfx45
rfx45's Avatar
What springs or coilovers do you have?
Will these solve the problem of rubbing? For example, I get an 18x8 w/ 40mm for the fronts and 18x9 w/ 40mm? I'm also planning on using the stock tires until it's dead if that helps a bit.
I also just don't want to bother with rolling fenders and rubbing that i would rather compromise and get a different width and offset even if it doesn't sit flush.
Old 05-22-08, 11:24 AM
passnu2
passnu2's Avatar
with +35 you will not rub. I have 19x8.5 + 33 and I am okay....not sure what tire size the other member is running but I am 235/35-19.
Old 05-22-08, 08:39 PM
dngo27
dngo27's Avatar
i am running 18x8.5 with a 25 offset with no problems. i have 235/40/18 tires. i did do the heat gun trick on a small part of the wheel well, but i dont rub on the fenders at all. i am also lowered on tanabe's nf210s. 25 offset looks super aggressive, so 35 will definitely work. good luck!
Max16
IS F (2008-2014)
11-24-16 08:06 AM
smokyis350
03-02-14 12:18 PM
mrohno
IS F (2008-2014)
05-16-10 12:33 AM
BigVIPness
Wheels, Tires & Brakes Forum
17
03-06-05 05:36 PM
Quick Reply: 18x8.5 w/ 35mm offset for the front, any problems?
