Parking Assist Volume Adjustment
Is there any way to adjust the volume of the parking assist buzzer without taking the car in to the dealer? (non-NAV)
I did a search and found nothing.
I was successful in programming my SmartAccess to unlock all the doors when touching the door handle or using the remote!
I use "..." ....... a lot
There should be no difference on changing this setting if you have navi or non-navi.
Super Moderator
Hold the "Info" button depressed while simultaneously switching the light stalk from "Off" to "Parking lights" rapidly. After about five repetitions, the diagnostic menu should come up. I don't recall an adjustment for the parking sensor volume in there, but it has been a while since I've perused those menus.
I got to it a different way IIRC. I think I held the info button and pressed repeatedly the top then bottom of the screen....of course, with no nav screen, that would be difficult......
Where does the menu show up in your example Bichon?
Super Moderator
Using the parking stalk method, it shows up on the nav screen, just as it did with the older method.
okay...Yes you can adjust the volume. Can some one with out Navi post how you change this!!
Here is the process for those with NAVI...
If you have NAVI-
Press INFO button.
Next press the Park Assist button on Navi Screen
Next screen allows you to set the sensitivity and the volume.
If you have NAVI-
Press INFO button.
If you have NAVI-
Press INFO button.
If you have NAVI-
Press INFO button.
The only interface that we have for park assist is the < o > buttons on the side of the dash. And, the only option it seems to give is the on/off capability, and I think hitting the info button on the steering wheel in this screen just cancels out the < o > display.
Maybe one of the Lexus Tech's on the forum can help us out.
