2IS aftermarket stereo question thread
#76
guys, anyone knows or try an aftermarket subwoofer that will fit where is the OEM stock sub...!!! I blown mine and I dont wanna get the oem. I want something that is stronger and also fit with no modification. I have searchd and nothing came up.......
#81
just like brociouz said, plus by putting an aftermarket sub, you must run the aftermarket amp, the oem amp will not push out the correct ohm load, and/or the correct rms, therefore damaging you more expensive higher quality aftermarket sub.
#82
Do I need to buy an aftermarket amp??? I don't want to buy an aftermarket amp, I just want to replace/swap the OEM sub with another aftermarket sub that can be used with the OEM amp... or can I used the JL sub with the OEM amp??
#83
because no one has done it to my knowledge without modification. you must modify to make it work. you also need an aftermarket amp.
yes it should be covered under warrenty
#84
Uber 1337 Moderator
#85
how many people have switched out their stock spears? Ive got two component sets waiting in my room to be installed, already got the amp too. I was told i would need a sound processor to make the midbass sounds come through. is this true?
#88
Fire Slayer
#89
http://www.ebay.com/itm/ROCKFORD-FOS...item4cfabc84f1
would i be able to use this one? Do i also need the summing units?
RA092423
09-26-06 04:18 PM
kmn5
02-16-06 09:01 PM
