Mark Levinson?
No need to test. It says Mark Levinson right on the front. It either says it or it doesn't. This is like asking if you have an IS 250 or 350.
Registered User
you have to be much more clear with your question. did you mean you want to install it after the car has already been built or have it installed when you special order it.
depending on your definition of "base" model, which could be absolutely base or the most common premium base (premium package, HID AFS, 18"). Either of those "base" models you would have to special order.
if you mean having ML installed afterwards, you could do that but it would cost ALOT. you would have to swap out the CD player, change the wiring harness, swap all the speakers and install the ML amp.
