So I got a nail in my tire
My TPMS warning came on this morning to tell me that the tire pressure was low. After having the dealer take a peek, it turns out that my driver's side rear tire got a nail stuck in its sidewall. It's not repairable and has to be replaced. The dealer suggested that I just switch out the damaged tire, but I only had about 40% tread remaining. With that level of wear, shouldn't I swap them both out?
Also, should I buy the tires from the Lexus dealer or should I go to NTB or Discount Tire? I was quoted around $275 each at the dealer.
discount tire or NTB might not have the tire size you need in stock, a lexus dealer will definately have the correct size tire. It just depends how long you want to drive on a spare tire (if discount or NTB doesnt have that size in stock) vs. how much money you want to save. I doubt you would be saving much.
Its up to you if you want to replace both. But 40% tread is still worth keeping
I'm actually still driving on the one with the nail in it! It's not flat, just my Tire Warning lights are on. Ugh, probably gonna go to Lexus to save time, because you're right. Discount tire and NTB need 2 days to get my tires in.
I'm glad you found the nail, but I'm surprised your first inclination when the TPMS light came on was to take the car to the dealer. I would probably have just put air in the tire first.
If a nail is in the sidewall or within about 3/4" of the sidewall on the main tread area it is unrepairable as it is in the flex zone. You may get a repairer to plug it .... but it is not recommended by the tire manufacturers. Overly conservative? Probably, no doubt due to lawsuit fears. Last time I was at Discount Tire they had a chart showing the 'NO REPAIR' zone. This zone is quite large. Going forward I think we will see more and more restrictions on repairing of tires.
I wouldn't replace both, just the bad tire.
Well... time to upgrade the back 2 to some F1 GS-D3 , you dont NEED to change all 4 at one time, if you stagger the changes it comes out to a much more livable bill.
You really have no choice but to replace the tire. NTB and Discount might be cheaper, but just make sure they know how to handle your tire sensors!! It might just lead to costly repairs later on.. To be on the safe side, bring it to Lexus, you wont have regrets and will have piece of mind, plus most likely, they will have your tire size in stock.. Haha plus you get a free carwash! And on the other note about patching a tire thats on the sidewall, most wont do it just because of fear of lawsuits, and it is not safe, just like everyone said, the patch wont hold every time the tire flexes.. So good luck!
Is it an AWD?
Something to consider might be the type of AWD system. Not sure what Lexus is using, but with 1 tire at 40% and the opposing tire at 100% the computer control may go nuts trying to compensate for the difference because it is reading 1 tire turning at a faster rate.
I think Volvo had a problem along these lines when they 1st released their SUV.
My inclination would be to replace the pair and maybe keep the good tire as a future spare.
good god $275 for a stock tire...damn! I wouldnt even pay that for a 20"
If i ever had to replace the stock tires...which i probably doubt since they are sitting in the garage. I would get a higher wear rating tire...not those 140 rated stock ones.
I had a nail in one of my rear tire recently. I went to a 24-hour tire repair shop to fix it. I wanted them to do the plug thing but they said they only do "patches". So they took the tire off the rim and patched it. Ever since then, my tire's been losing 10 PSI every 2 days or so. I went back a few times already to look for the dude that fixed my tire but he's never working at the time I go. I'm just not happy about the fact that I spent $20 to try to get it fix and I'm gonna have to end up spending more money to fix it again.
