Old 12-15-14, 01:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
DIY aftermarket amp power wire install step by step with pictures
Old 06-01-11, 05:18 PM
  #106
takadakeyo
takadakeyo's Avatar
Im planning on installing an aftermarket double din and want to run my speakers through a aftermarket 4ch amp connected to my double din. I look at my stock amp and was wondering if anyone could help me with what wires go to which channel. its a pretty small amp 50rms x 4 @ 2ohms.
Old 06-28-11, 12:27 PM
  #107
aznpapaya
aznpapaya's Avatar
alright so i'm planning on install an aftermarket sub and amp. This will be my first install but I've been reading a lot of thread on here and think that I'm ready to start the installation. I reed on this thread that people used t-tap instead of splicing the stock amp wires. I was looking into buying some t-tap but sure which one to buy. they have t-tap for 10-12 gagae, 14-16 gauge, and 18-22 gauge. Which one should i buy. thanks
Old 06-28-11, 12:51 PM
  #108
Pnuge88
Pnuge88's Avatar
normal 14-16 gauge will work. this thread will answer anyquestions you have. i installed my first system using this thread as a guide. not hard at all. good luck!
Old 06-28-11, 12:52 PM
  #109
kumquatism
kumquatism's Avatar
I used the 18-22 gauge ones. The speaker wires coming from the amp are very small.
Old 06-28-11, 12:57 PM
  #110
Pnuge88
Pnuge88's Avatar
oh btw. for those of you that are tapping into the door speakers.. DON'T! i learned this from the SC guys.. the sub systep sounds 100X better when you tap into the SUBWOOFER signal itself.. don't know why the hell we even tapped into the door speakers... i don't know which color it is on the connectors behind the amp.. but i just stole signal from the connector attached to the OEM sub itself. worlds difference!
Old 06-28-11, 03:01 PM
  #111
kumquatism
kumquatism's Avatar
I tapped both, running the subs on 1 channel, left woofer on 1 channel, and right woofer on another channel. The mid woofers are to bypass the original LPF that the amp puts out to the sub. I think the original sub only has the really low bass, so you're missing out a little bit of the higher frequency bass. IDK, I couldn't really tell much difference between the two, but my tuning might be off.
Old 06-28-11, 03:46 PM
  #112
01ES300NYC
01ES300NYC's Avatar
can anyone tell me if the wires to tap for the front right woofer and front left woofer are on the same connector ?
Old 06-28-11, 04:07 PM
  #113
kumquatism
kumquatism's Avatar
^^They are on the connector that's closest to the rear of the car (on Non ML, IDK about ML). The colors are brown and pink for one woofer, and red/white for the other. I don't remember off the top of my head which one is the left woofer and which is the right.
Old 06-28-11, 04:30 PM
  #114
01ES300NYC
01ES300NYC's Avatar
thanx...
Old 06-29-11, 06:55 AM
  #115
aznpapaya
aznpapaya's Avatar
does anyone here know which wires is need to tap for the stock sub to my afftermarket amp?
Old 06-29-11, 07:51 AM
  #116
sushiboi
sushiboi's Avatar
I can go take a quick pic of mine right after lunch.. i'll post it and let you know
Old 06-29-11, 07:57 AM
  #117
sushiboi
sushiboi's Avatar
Default Wire diagram
I found this on my comp.. Forgot I had it. It really helped me. GL
File Type: pdf
Old 06-29-11, 08:09 AM
  #118
aznpapaya
aznpapaya's Avatar
thanks for the diagram, i'll be sure to study it before i start the install. But if you can can you please take a pics of your wires tap too. The more info the better
thanks
Old 06-29-11, 10:18 AM
  #119
kumquatism
kumquatism's Avatar
I didn't drive my car to work today so I cant get you a picture of my actual tapping, but the wires are found on the 3rd connector from the rear of the car. For non ML, they were the first 4 wires from the front of the connector. I only tapped one set though. I believe they were brown+ green- pink+ and blue- wires, and I tapped the brown/green set.
I dug up a pic that I took (terrible quality), and I drew a circle around the ones to tap:
Hope this helps!!
Old 06-29-11, 10:35 AM
  #120
sushiboi
sushiboi's Avatar
thanks
PM your email address. The pics are too big to post on here.
Quick Reply: DIY aftermarket amp power wire install step by step with pictures
