Old 12-15-14, 01:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
DIY aftermarket amp power wire install step by step with pictures
Old 07-11-16, 01:09 PM
  #286
drwafk
drwafk's Avatar
Originally Posted by Chyabrah
Reviving the dead!
Has anyone done this on a third gen? I am having issues getting the power to the trunk.. I cleared the fire wall and got to the back door door sill but can't seem to get back to the trunk. If anyone has any experience that would be great. I have a 2015 non-ml..
thanks!
I do not have a 3IS but I cant imagine it'd be too different from 2IS. Pull out the back seat to get your power, accessory, and (optional) bass remote through. Good luck.
Old 07-11-16, 04:43 PM
  #287
iJDMTOY
Former Sponsor
iJDMTOY's Avatar
Awesome guide! Looks like a lot of people are already benefiting from it!
Old 07-11-16, 07:55 PM
  #288
Chyabrah
Chyabrah's Avatar
Ha thats what I was hoping, Does the 2IS back seat fold down also? I feel like that's where they might be different. Sheazy seems to have pointed me in the right direction. Might post my thoughts after i am done for those working on the newer model if there are any notable differences..
Old 07-24-16, 03:07 PM
  #289
Chyabrah
Chyabrah's Avatar
Well finally found some time this weekend to finish wiring this thing up. Good news I have power to the amp. Bad news I must of messed something up with the signal wiring because the sub isn't producing any bass.. at all.
I followed the wiring diagram on the following post Here
Any suggestions on where to start with my problem solving? I made sure my sub was wired at 2ohms, checked with multi meter. I am running a Hilfonixs amp w/ the scosche LOC which has been used by other here... Some basic questions, what is the black wire found on the scosche? Secondly it has the option for common ground, factory amp, and line out, what do I set this to?
Any help would be greatly appreciated! Thanks.
Old 03-08-17, 07:44 PM
  #290
FFM
FFM's Avatar
With a sub/amp combo with integrated LOC that only has inputs for the L/R side speakers, any reason you couldn't tap one of the door speakers and the sub wires directly into it rather than using an external LOC?
This is what I purchased and will be this friday. I may just try inputting the sub wires only and then try a door speaker after as a test if no one has tried this before. Worst case scenario I go buy one of those cheap 4 channel LOC's from walmart like mentioned in this thread and do the sum setup. But would rather just use the internal one if I can.
Old 04-26-17, 08:09 AM
  #291
mahamed21
mahamed21's Avatar
Default How many rca cables needed
how many rca cables are needed ? My amp only has 2 inputs for rca ? How does this work? Thanks
Old 05-01-17, 04:42 PM
  #292
FFM
FFM's Avatar
Just the one pair. From the LOC to the sub amplifier.
Old 05-01-17, 04:45 PM
  #293
mahamed21
mahamed21's Avatar
if im tapping to the front woofers and the subwoofer thats 4 channels. Why do i need only a pair and not two
Old 05-01-17, 05:02 PM
  #294
FFM
FFM's Avatar
The RCA's are what's going to send the signal from the LOC to the amplifier. The inputs to the LOC are just standard wire taps.
Old 05-01-17, 05:05 PM
  #295
mahamed21
mahamed21's Avatar
so if though i tap to 4 channels i only need pair rca going to my amp? I will still get signals from the front woofers and sub ?
Old 05-01-17, 06:19 PM
  #296
FFM
FFM's Avatar
You need to physically tap those references with standard wiring to the 4 channel LOC. Then run a pair of RCA's from the output of the LOC to the sub amplifier.
Old 05-03-17, 04:03 PM
  #297
mahamed21
mahamed21's Avatar
Originally Posted by PhiDeltBee
After a LOT of testing, the best bet is to tap BOTH, the mid woofers AND the sub. I had just tapped the mids and was missing a LOT of the low freqs. If you only tap the sub, and want to set the amp crossover a bit higher, you can't. Best bet is to tap both. If you decide to just tap one or the other, the sub will be "better" than the mids. I spent 3 weeks playing with this and until someone can post what the stock amps cut offs as far a freqs are concerned, you're better tapping both and summing the signal together. My stereo sounded like crap just tapping the mids for my aftermarket sub as no frequencies could be heard below 60hz or so.
how did you sum it up
Old 05-06-17, 08:23 AM
  #298
mahamed21
mahamed21's Avatar
[QUOTE=a4rings;8756556]
Originally Posted by tt061880
After a few days of testing different approach to get the signals. I have decided that the Scosche 4channel LOC is the best bang for the buck, screw the cleansweep and AudioControl. Two channel LOC would work but 4 channel works better, here are the reasons why.DID YOU FIGURE OUT? How do you sum up the wronnt woofers?
The ML amp put a lot of power into the sub, I know this for a fact because when I switching the input the signals from the sub and the front door woofer, I noticed that the sub signal is significantly higher. If you have a 2 channel LOC, you can use one for the sub and one for the front door woofer. You must then adjust the input level from the stock sub lower to match with the front woofer.
I also tested the signals from the two front woofers, they carry a lot of midbass. If you have signal from either one of the front woofer, the signal is only half compare to using both(I achieved this by using a Y RCA cable).
The best solution I found is SUM up the two front woofer to one channel and the subwoofer on a channel by itself. By doing it this way, the setup sounds SO MUCH better than before. I can actually listen to the lows without getting a headache like it was before
Also, although the wires going into the rear door is full range, the ML amp barely send any wattages in there. It isn't worth getting the signal from the rear speakers so you can can ignore it.
here are the pictures
after everything is in place
can someone please explain what is going on with the RCA's in this picture? I only have two RCA connections on my amp.
In this picture, where are the two RCA's on the left going? and the 4 RCA's on the right?
thanks guys
Old 05-31-17, 07:43 AM
  #299
MIca250
MIca250's Avatar
Hey everyone I am having trouble with my intake and was wondering if someone can help me out. Okay so I installed 4 new door speakers and 4 new tweeters, I ran new speaker wire to the aftermarket amp and I tapped into the wires coning out of the factory amp using a line out converter. I don't have any sound at all. What am I doing wrong?
Old 03-20-19, 09:38 PM
  #300
jacobalan
jacobalan's Avatar
hey guys i need some help with my 2012 non ml system.... i have both subwoofer channels hooked up to my LOC, however i’m trying to get my front door woofer signals hooked up to it as well. i have found out that the facelift model of the 2is (2011-2013) has different wire colors than those stated in all the other threads and diagrams. i have been searching for this info for 3+ hours... if someone could let me know, all i need to know is the front door woofer + and - channels for both doors. and which connector it’s on. i believe it should be on connector 3 if you’re reading the amp like this: [1 2 3 4]
Quick Reply: DIY aftermarket amp power wire install step by step with pictures
