Old 12-15-14, 01:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
DIY aftermarket amp power wire install step by step with pictures
Old 09-22-07, 07:31 AM
Technique
Technique's Avatar
bump! I'm going to be re-wiring my sub today with the same 4-chan LOC that tt061880 used... The goal is to get a more full-range and balanced signal going to my subwoofer... I'll post the results later...
Old 09-22-07, 09:47 AM
tt061880
tt061880's Avatar
good luck!
Old 09-22-07, 10:56 AM
Technique
Technique's Avatar
Default Success!
Huge thanks to tt061880 for taking the time to explain what he did and why...
I basically did the exact same thing, except I decided only to use 2 channels, the subwoofer, and only ONE of the front woofers... I individually balanced each channel and the result is SO MUCH better... I now have full bass frequency, not just the 30-80hz provided by the stock subwoofer speaker... I turned the crossover on my JL Amp on and everything sounds perfect... 30hz to around 100hz... The lows are balanced with the rest of the system now as well...
Here are a few pics as always..
First- The wiring harness from the factory ML amp that I cut into:
Second - The factory amp with Scosche 4-channel LOC tucked away nicely:
Third - With the cover on, it looks just like factory:
Fourth - View of the trunk, you can see the JL amp mounted under the rear deck:
Thanks again to tt061880!!!!
Old 09-22-07, 05:45 PM
tt061880
tt061880's Avatar
you're welcome man, glad you like it, I figured the SUB output alone wasn't enough the first time I heard it, it has a lot of bass but it was missing a lot of notes.
Old 09-23-07, 12:24 AM
DJKIBBLES
DJKIBBLES's Avatar
Awesome WRITE Up!
Old 11-09-07, 04:28 PM
BlackGhost
BlackGhost's Avatar
I have a question?
When you sum the front channls togather,do you lose sound as well as quallity? also does the Nav directions sound the same or lower when you use it?
Old 11-12-07, 09:23 AM
05LSV
05LSV's Avatar
Another question - what was the purpose of using both the front left AND front right speakers (as well as the sub of course) and combining them to feed into the LOC, as opposed to just the front right OR the front left.
Do you believe you got a more balanced sound by combining the front left and right?
Old 11-12-07, 08:04 PM
Technique
Technique's Avatar
Originally Posted by BlackGhost
I have a question?
No changes. You are just tapping into the front channels, not changing anything about what you hear from those speakers...
Old 11-12-07, 08:05 PM
Technique
Technique's Avatar
I only did one of the front channels, the left I believe... Doing both is better because you will get a fuller range of sound since most recordings are 2.0 (left and right) and certain bass notes MIGHT be only on one channel, but are usually on both...
Old 11-14-07, 09:52 PM
05LSV
05LSV's Avatar
thanks for the input.
Old 02-19-08, 07:59 PM
iialcii
iialcii's Avatar
Thanks tt061880 for spending time on explaining everything thru PM's and troubleshooting my amp install. very helpful thread and member
forgot to take a pic but here is what i did with instrument panel on the left with the dead panels. Sub on/off switch, bass *** and led light on/off indicator.
i know its crooked but this is when i first installed it. its straight now. i kinda scratched the bass *** slot.
Old 05-20-08, 09:32 AM
VTLexus
VTLexus's Avatar
how much of this original post applies to non ML owners? I am planning on doing my own sub install, but I don't have ML. Any suggestions?
Old 05-20-08, 04:07 PM
livinitup7
livinitup7's Avatar
Would like to know as well, as far as wire tapping and colors to use. Great thread.
Old 05-20-08, 05:19 PM
WhatYaGot
WhatYaGot's Avatar
I have the non-ml system. I used this post's information:
T-tap wires on the front woofer speaker wires. The right front door woofer wires are Brown (+) and Pink (-). The left front door woofer wires are White (+) and Red (-). Or you could just tap the factory sub wires to the new amp. The sub factory wires are sort of confusing on the schematics I have. The wires are either Pink (+) and Sky Blue (-) or Brown (+) and Light Green(-). Just pick the colors that are at the speaker for your install.
I am waiting to have someone tell us for sure which is the remote turn on for the non-ml system. I have heard different colors, but need someone here to let us know for sure. Right now my amp stays on while the car is on. Need to change this ASAP.
Old 05-27-08, 02:43 PM
VTis250awd
VTis250awd's Avatar
I have to remove the bench of my back seat anybody have somewhat detailed instructions on how to do this? I cannot figure it out by just looking at these pics.
thanks
Eric
Quick Reply: DIY aftermarket amp power wire install step by step with pictures
